brake light
Old Apr 2, 2007 | 12:41 PM
SXTspeed's Avatar
SXTspeed
Default brake light
got a question for you guys. Since I drive an ATX I usually don't put the parking brake on. But sometimes when i am leaving work when i take the car out of park and slide it into drive and hit the gas the brake light comes on, when the parking brake is not set. Why is this?
Old Apr 2, 2007 | 12:56 PM
l_pillon's Avatar
l_pillon
Default RE: brake light
are u givin it gas before ur fully out of park?
Old Apr 2, 2007 | 04:12 PM
tooslow's Avatar
tooslow
top of your brake fluid
Old Apr 2, 2007 | 06:27 PM
SXTspeed's Avatar
SXTspeed
yeah usually i park so that i have to back up and then put it in drive and go. For some reason if i hit the gas in reverse it is fine but then I stop and put it in drive and hit the gas and it comes on.
I will try topping off brake fluid
Old Apr 3, 2007 | 01:07 AM
ek2588's Avatar
ek2588
this maybe a stupid question but are your brakes sqealing?Is everything in good mech. order and its just the light coming on. It might be the self adjusting screw in the rear drum brakes. im not sure on this so correct me if im wrong but like i said i might WAY off lol.
Old Apr 3, 2007 | 01:47 PM
SXTspeed's Avatar
SXTspeed
yeah it is in good mech order. they squel a little but that is usually just after they are wet.
Old Apr 3, 2007 | 03:28 PM
l_pillon's Avatar
l_pillon
they sqeal cuz neons brakes rust up and every time u drive ur takin that rust off...the only way to fix this is to upgrade ur breaking unit
Old Apr 3, 2007 | 03:36 PM
tooslow's Avatar
tooslow
ok here is why I said top of your fluid as the pads wear down they stay closer too the rotor so there is less fluid in the resiovor and more in the lines and calibers. the senser for the resiovor sits in the front so when you pull away like bat out of hell the fluid moves back and the senser think the fluid is low triggering the brake light
