Need a Battery Cover and Temp Sensor
Old Apr 6, 2007 | 02:10 PM
chazlewood75's Avatar
chazlewood75
Default Need a Battery Cover and Temp Sensor
After getting my EVAP leak fixed, I now need to take care of the other code I had which said that I had a high battery temperature.
The battery that came with the car is a size too big. I was told that I need to get the proper size battery or I might have issues with the clamps wearing a hole in it. I am missing the battery cover AND the actual temperature sensor that plugs into the cover. I asked the parts department about it and they said they could order it for about $50. Anyone know where I can get one that is new or like new for less than $50?
Old Apr 8, 2007 | 04:34 PM
neon03se's Avatar
neon03se
Default RE: Need a Battery Cover and Temp Sensor
how did you get the evap fixed
Old Apr 9, 2007 | 03:46 AM
Adionik's Avatar
Adionik
How much was it to fix your evap?
I got two codes saying I have two leaks.
Old Apr 9, 2007 | 12:54 PM
chazlewood75
I did what I would to try to find a leak myself. First think I checked was the gas cap. I looked at the cap itself for cracks and then at the gasket for breaks in the rubber. But after I could not see any breaks in the vaccum hoses, connectors, or gas cap, I was forced to take it to a dealership to get it smoke tested. Missouri is not a smog state so there was no "garage" that specializes in that. It costed me $101 for the test and parts and labor to get it fixed. Then they told me what I needed to fix the high battery temperature problem.
That is why I am looking for a battery cover and temperature sensor.
