transmission flushing
Old Apr 10, 2007 | 05:24 PM
sanel's Avatar
sanel
Default transmission flushing
i want to flush my transmission
any instructions will be helpfull
how to figure out the transmission hoses, as in which one is
inlet and which one is outlet from the radiator or the transmission
Old Apr 10, 2007 | 05:25 PM
sanel's Avatar
sanel
Default RE: transmission flushing
forgot 2004 neon sxt
thanks
Old Apr 10, 2007 | 05:29 PM
03neonRT's Avatar
03neonRT
Here are the instructions to flush an MTX and put in the new fluid, along with how to check the fluid level...
[IMG]local://upfiles/24091/4024B655D4904D699533B00ADB10DD69.jpg[/IMG]
[IMG]local://upfiles/24091/089258B6460447DB9E47BC2AEA8CF498.jpg[/IMG]
[IMG]local://upfiles/24091/F38A90A81C674AE3B456EB07605F34AB.jpg[/IMG]
Old Apr 10, 2007 | 05:51 PM
sanel's Avatar
sanel
forgot one more thing, it's automatic transmission
thanks
Old Apr 10, 2007 | 05:54 PM
03neonRT's Avatar
03neonRT
For an ATX...directly from the Neon FSM:
FLUID/FILTER SERVICE (RECOMMENDED)
(1) Raise vehicle on a hoist. Refer to LUBRICATION
and MAINTENANCE for proper procedures.
Place a drain container with a large opening, under
transaxle oil pan.
(2) Loosen pan bolts and tap the pan at one corner
to break it loose allowing fluid to drain, then remove
the oil pan.
(3) Install a new filter and o-ring on bottom of the
valve body (Fig. 182).
(4) Clean the oil pan and magnet. Reinstall pan
using new Mopar Silicone Adhesive sealant. Tighten
oil pan bolts to 19 N·m (165 in. lbs.).
(5) Pour four quarts of Mopart ATF+4 (Automatic
Transmission Fluid) through the dipstick opening.
(6) Start engine and allow to idle for at least one
minute. Then, with parking and service brakes
applied, move selector lever momentarily to each
position, ending in the park or neutral position.
(7) Check the transaxle fluid level and add an
appropriate amount to bring the transaxle fluid level
to 3mm (1/8 in.) below the lowest mark on the dipstick
(Fig. 183).
(8) Recheck the fluid level after the transaxle has
reached normal operating temperature (180°F.). Refer
to Fluid Level and Condition Check for the proper
fluid fill procedure.
(9) To prevent dirt from entering transaxle, make
certain that dipstick is fully seated into the dipstick
opening.
AND...
DIPSTICK TUBE FLUID SUCTION METHOD
(ALTERNATIVE)
(1) When performing the fluid suction method,
make sure the transaxle is at full operating temperature.
(2) To perform the dipstick tube fluid suction
method, use a suitable fluid suction device (Vaculaâ„¢
or equivalent).
(3) Insert the fluid suction line into the dipstick
tube.
NOTE: Verify that the suction line is inserted to the
lowest point of the transaxle oil pan. This will
ensure complete evacuation of the fluid in the pan.
(4) Follow the manufacturers recommended procedure
and evacuate the fluid from the transaxle.
(5) Remove the suction line from the dipstick tube.
(6) Pour four quarts of Mopart ATF+4 (Automatic
(7) Start engine and allow to idle for at least one
(8) Check the transaxle fluid level and add an
(Fig. 183).
(9) Recheck the fluid level after the transaxle has
(Refer to 21 - TRANSMISSION/TRANSAXLE/AUTOMATIC
- 41TE/FLUID - STANDARD PROCEDURE)
(10) To prevent dirt from entering transaxle, make
opening.
