MS
Old Apr 21, 2007 | 03:30 AM
2004neonR/T's Avatar
2004neonR/T
Default MS
Hey if you decide to go with the pre-assembled MS they dropped in price at rs auto sport theyre now 365 dollars. And also I got a question since I am going with preassembled unit does the Wiring Harness re wire the entire engine bay I want to keep the stock PCM for the accesories??? If any one knows thnx
Old Apr 21, 2007 | 03:34 AM
2004neonR/T
Default RE: MS
Also another question Is it plug and play???
Old Apr 21, 2007 | 04:18 AM
spikeymikey87's Avatar
spikeymikey87
Default RE: MS
no not plug and play. you will need the grounds and stuff and then the 4 injectors, 2 coil pack wires, tps, crk pos, read up www.megasquirt.info at lease 2 or 3 times fully before you even begin to think about it lol you will let the pcm take care of everything except fuel and spark. you will also have the cel on
Old Apr 21, 2007 | 05:22 AM
03neonRT's Avatar
03neonRT
Default RE: MS
ORIGINAL: spikeymikey87
Indeed...you should have that entire site practically memorized...and yeah, you'll probably throw around 10-15 CEL codes while on MS...
Old Apr 21, 2007 | 05:10 PM
spikeymikey87
Default RE: MS
ORIGINAL: 03neonRT
6 codes i think. 1 for each injector and then i thik 2 for the spark, unless there are more for the spark
Old Apr 23, 2007 | 03:17 AM
2004neonR/T
Default RE: MS
Alright Ive done all that I have decided to go ahead and still get the MS preassembled kit. I am also eting the relay board it will help keep things neater under the hood. I can use the relay board right??? lol
Also I have to buy new injectors or can I reuse the stock ones
Old Apr 23, 2007 | 04:05 AM
2004neonR/T
Default RE: MS
What are the Dimensions on the Box for the MS
Old Apr 23, 2007 | 11:27 AM
tooslow's Avatar
tooslow
Default RE: MS
I had the relay board the cable is one pain in the *** too assemble I would get the rs wirring set it is makes the install easier too
Old Apr 23, 2007 | 11:25 PM
rtneon67's Avatar
rtneon67
Default RE: MS
is there anyway u can do ms and not get the cel
Old Apr 23, 2007 | 11:26 PM
spikeymikey87
Default RE: MS
yea have some old injectors hang off a wiring harness connected to your stock comp and same with coil pack. wont be too good of an idea to do that though
