03neonRT
I posted this in the other thread...
You have two options on where to get the kit...first, you could call or go to your local dealership and have them look up the actual part numbers for the kit (i'll list them in a second). However, some dealerships are not selling the kits at the correct price (some are much higher, and some are a little lower), so your other option is going to MoparSuperCenter.Com and typing in the same part numbers under the search button. The correct pricing will come up after that. From the dealership the front/rear kit is $99 and the side skirts are $69. MoparSuperCenter has them for slightly cheaper, but then you have to pay for shipping, so it kind of evens out.
Here is the list of part numbers, and how many kits there are left nationwide. Once these are gone, they are gone forever since FCx wont be making anymore.
AS OF 4-25-07 (7:00AM Eastern Standard Time)
82208077 BLACK - FRONT AND REAR - $99 (QTY 432)
82208210 BLAZE RED - FRONT AND REAR - $99 (QTY 683)
82208082 SILVER - FRONT AND REAR - $99 (QTY 295)
82208083 PRIMER - FRONT AND REAR - $99 (QTY 0)
82208084 BLACK - SIDES - $69 (QTY 0)
82208209 BLAZE RED - $69 (QTY 206)
82208085 SILVER - $69 (QTY 67)
82208086 PRIMER - $69 (QTY 0)
SRT Style Spoiler
82208411 BLACK - SPOILER - $69 (QTY 150)
82208412 BLAZE RED - SPOILER - $69 (QTY 234)
82208413 SILVER - SPOLIER - $69 (QTY 0)
82208414 PRIMER - SPOILER - $69 (QTY 0)
SRT Style Spoiler
ORIGINAL: spikeymikey87
**** that sucks. did you replace your thermostat? id say swap it out anyway. get a 180 one
ORIGINAL: tooslow
did you take te head of when you did the cam. I you did check for bubles in the coolant it normally means a blown head gasket. But for your part I hope it is the thermostat
I drove the car 50 miles today and my engine temperature went so high that i got the warning alarms and everything. The radiator fan is only turning on when the A/C is on (but even when its on it still overheats) and the coolant is full. When I turned the car off and popped the hood some steam was rising from somewhere...the general area was around the thermostat housing, but it didn't look like it was actually coming from the housing itself. When i squeezed the radiator hose it made a hissing noise then a bubbling noise, along with the steam still.
well when you are driving, it will keep the car a tad cooler (stock thermo is 195) which will make the car work more efficiently. the reason it is so high is for emissions, but it will run a little better cooler.
