which should i do
Old Apr 22, 2007 | 03:39 PM
jayjay71787's Avatar
jayjay71787
Default RE: which should i do
should i put an srt4 engine in it?
also is this all things i can do myself
Old Apr 22, 2007 | 04:09 PM
snare_samn's Avatar
snare_samn
Put a turbo charger in it. I put one in my 2000 neon and it accelerates much faster now. I love it.
Old Apr 22, 2007 | 05:59 PM
night709's Avatar
night709
What would be needed to put a turbo charger in it?
Old Apr 22, 2007 | 06:09 PM
AirWolf's Avatar
AirWolf
Hahn is what I would go with if I were you they are brand new and not used like a srt4 and you can use some srt4 parts with it if you wanted to .
Old Apr 22, 2007 | 08:39 PM
jayjay71787
someone told me a turbo charge wouldnt work in my car beczuase if i go to fast my axels would snap
so i shouldnt put an srt4 engine in my car?
Old Apr 22, 2007 | 08:50 PM
AirWolf's Avatar
AirWolf
I would go with a hahn turbo kit the guy that said that has a hahn stage1 turbo kit in his 00 neon and I have a stage2 hahn kit in my 1st gen neon works great.
Old Apr 22, 2007 | 09:13 PM
jayjay71787
so what that kid said is wrong about me goin to fast that the axel will snap? he said it would snap because i needed to upgrade my suspension
Old Apr 22, 2007 | 10:25 PM
Andpto's Avatar
Andpto
ok the way to make your neon faster is put an srt-4 motor. It already comes with a turbo so u set to go. Our 2.0 engines werent designed for a turbo. So in order to put a trubo in u have to change alot of your stockinternals to able to run a higher boostwhich is very expensive.some people can say u can run under 7psi on stock internals but it ruins the life of your motor. And no your axles wont snap with a turbo from what ive heard. When u upgrade yoursuspension its springs, and struts or coilovers or sway bars, not your axle....
Old Apr 22, 2007 | 10:40 PM
jayjay71787
i might skip on the engine if i was to buy a new engine i might as well jusst buy a new car
Old Apr 23, 2007 | 12:45 AM
Andpto's Avatar
Andpto
yeah thats what im going to do because i rather buy an SRT4 than do a swap. You can always turbo your neon.
