anyone with short ram air intake?
Old Apr 24, 2007 | 01:20 AM
l_pillon's Avatar
l_pillon
Default anyone with short ram air intake?
just curious to how good they are..i dont want an intake that mounts into the wheel well....wonderin if u can send me some links to some sites that sell them with the install instructions so i can see if they will fit..i have a 2000 neon
Old Apr 24, 2007 | 01:50 AM
Andpto's Avatar
Andpto
Default RE: anyone with short ram air intake?
http://www.knfilters.com/search/prod...x?Prod=57-1534
there is your short ram from K&n they have picture instructions
Old Apr 24, 2007 | 01:54 AM
l_pillon's Avatar
l_pillon
Fuel Injection Performance Kits doesnt say anything about short ram intake....i believe the short ram is a 69 series but thanks anyways
Old Apr 24, 2007 | 02:40 AM
Kapitald's Avatar
Kapitald
this is a short ram intake man....note the filter??? They just put that heat shield there so the air will be a lil bit cooler before it goes into the throttle body...cooler air means more power...also you wouldnt have to worry about this heat problem if you just put a CAI in the wheel well...
Old Apr 24, 2007 | 03:02 AM
l_pillon's Avatar
l_pillon
u dont get it..when its real cold and u got the intake in the wheel well things can get clogged up and it can seriously harm ur car,,,,winters here a bitter cold and u could possible get some engine problems havin the intake comin down the wheel well....thats y i want the shorty so i never have to change it back and fourth
Old Apr 24, 2007 | 03:37 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
for the 2.0, the only thing to be wary of on a short ram is some of the cheaper ones that just let it 'hang' there off of the throttlebody. you want one that is actually supported. im not sure of the 2.0 but i know for the 2.4, the K&N typhoon switches between WAI and CAI very easily.
and while hydrolocking is a danger, you pretty much have to submerge the entire filter for this to be a problem. even so you can have a valve installed that can avert this potential pitfall. but in then end there really isnt a huge difference between wai and cai. personally i switch the a wai during the winter and put thecaiextension onduring the summer months. it takes the better part of 10 minutes to swap out.
Old Apr 24, 2007 | 12:47 PM
SXTspeed's Avatar
SXTspeed
03neonRT told me a while ago that a regular cold air intake is better than short ram.
Random fact: 10 degrees cooler air = 1% hp increase
Old Apr 24, 2007 | 09:06 PM
Pablodragon's Avatar
Pablodragon
2 things, here's apic of mine... just made my own supports, some people don't use any at all and said they never had a problem, but I didn't want to take chances and just made these...
the other thing, just to make sure you know, it sounds like u think the air filter is right out in the open inside the wheel well...it is actually behind a panel, protected...and I beleive the filter ends up getting the air from the front grill....if you buy one, you will need to remove that panel to mount it.... obviously I don't have one, but have read a number of posts talking about it
Old Apr 24, 2007 | 09:26 PM
LowSlowNeon's Avatar
LowSlowNeon
ORIGINAL: l_pillon
Do you have any experience with that happening or is that just what you assume will happen?
Old Apr 24, 2007 | 11:33 PM
l_pillon's Avatar
l_pillon
my dads a service manager at a shop that does over a million in sales a yr..i was doin the research myself unitl he found out n told me about it....it be a diff story if i was in a warmer area but im not
