who has most hp
Old Apr 26, 2007 | 10:49 PM
tyler819's Avatar
tyler819
Default RE: who has most hp
How much hp do u think i will have with an aem cai, aem cam gear, comp 400 cam, crane valve springs/retainers, longtube header, 60mm tb, mpx udp, solid motor mounts,a stage 2clutch and a lightweight flywheel, 16' 15lb rims, and no cat? Also do u guys have any other ideas on whati canget to add some more hp that doesnt involve new pistons or turbo or nitrous?
Old Apr 26, 2007 | 10:58 PM
spikeymikey87's Avatar
spikeymikey87
i have the most hp PERIOD
Old Apr 27, 2007 | 12:01 AM
mikesxt's Avatar
mikesxt
why dump so much performance money into ur cars if ur only getting them to like 150 hp max?
Old Apr 27, 2007 | 12:02 AM
mikesxt's Avatar
mikesxt
and i guess im just going for turbo...what will i need to do < in laymans terms> and how much total when all said and done.....including installation < price and hp>
Old Apr 27, 2007 | 12:12 AM
AirWolf's Avatar
AirWolf
ORIGINAL: 03neonRT
ORIGINAL: AirWolf
Well the mods I just got not to long ago are mpx 60mmtb,walbro highflow fuel pump,mpx underdrive pully,aem ajustable cam gear,msd coilpack, just changed my wires to msd ones and i have platiunm plugs said I would never change but I did changed over to champions for the plugs I have a custom cold air not short ram intake also my srt exhaust with glasspack vibrant front strut bar and will have race red motor mounts . so how much hp do you think all this should get me and Im still stock with 15inch rims but wider tires .
The only engine mods you have that would actually "add" power are the 60mm TB, custom CAI, and UDP. The adjustable cam gear is worthless without a Crane 14 or larger cam, the plug wires only help with a smoother idle, and the coilpack and fuel pump wont do anything without serious engine mods. The motor mounts and wider tires will help with traction, but not add any power obviously. The SRT-4 exhaust doesnt really add any power either, since its not much less restrictive then the stock SXT exhaust system...so your prbably still looking at 115whp maybe a little more.
I guess I will be adding a crane 14 and what other mods but turbo could I add to help out the coilpack and fuel pump to get 150 hp or a bit more . What exhaust does help with the mods I have and will add very soon . my sxt is purely for show but still want to have a little go when I need it .
Old Apr 27, 2007 | 12:14 AM
Clokwerck's Avatar
Clokwerck
I definately have the most at stock.........[8D]
Old Apr 27, 2007 | 12:22 AM
contagious19's Avatar
contagious19
well i still got more mods to go. ima get up there
Old Apr 27, 2007 | 12:25 AM
neoncrazy101's Avatar
neoncrazy101
at the crank. take the base line of 132 - 10-15 for age, add a CAI and then subtract that due to the lack of back pressure on the exhaust and u get 122 lol.
Old Apr 27, 2007 | 12:28 AM
Clokwerck's Avatar
Clokwerck
lol Yes, definately amazing right there, that's power....
Old Apr 27, 2007 | 12:32 AM
spudsterier's Avatar
spudsterier
ORIGINAL: AirWolf
the walbro wont make any difference with the stock regulator in there....still gonna be pushing out the same fuel pressure as a stock pump......get an aftermarket regulator with larger injectors to bennefit from this....though it wont do your motor any good unless you have mad mods
i wish i knew a ball park figure of how much hp i will have once the car gets goin again....hopefully within a couple weeks[&:]
