Transmission fluid change
Old Apr 28, 2007 | 08:39 PM
jsweezer's Avatar
jsweezer
Default Transmission fluid change
2005 Neon sxt
Want to change my transmission fluid , I went to Kragen and got a filter it cane with a cork gasket. should I use the cork gacket ? also what are the torque spects for the transmission filter bolts?
Old Apr 28, 2007 | 08:56 PM
ewetho's Avatar
ewetho
Default RE: Transmission fluid change
2004 uses no gasket just 1/8" bead of RTV around the cleaned case cover and around each bolt holt and torqued to 165 in/lbs about 14 ft/lbs.
Old Apr 29, 2007 | 07:14 PM
NHARINTON's Avatar
NHARINTON
be crazy careful torquing the bolts on. They are suposed to go to about 13.5 - 14 ft pounds. AND THATS IT!! i had 3 strip out at 15 lbs. I would not torque more then 13 lbs. just make a nice bead of rtv and it wont leak. dont use the cork!
