2000 plymouth neon problem
Old May 6, 2007 | 04:11 PM
littlebeardanny's Avatar
littlebeardanny
Default 2000 plymouth neon problem
hello out there can anyone give me a soultion to this problem my 2000 neon had a head gasket put in and timing belt plugs and wires, when i get up to 55-70 mph the car seem to misfire or jerk not all the time i put a new gas filter and coil but it always come back to doing the same thing, no check engine light is on the car run fine at idle and at take off, if anybody can help please do so.[&o][&o][&o][&o]
Old May 6, 2007 | 05:56 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: 2000 plymouth neon problem
have you tried throwing a bottle of injector cleaner in it?
Old May 6, 2007 | 06:21 PM
littlebeardanny
no i have not will this do the trick
Old May 6, 2007 | 07:01 PM
Freerider's Avatar
Freerider
ORIGINAL: littlebeardanny
it might. It sounds like your car is starving for either fuel or spark at at higher speeds. So, if you replaced your spark plugs you need to check your injecters. The injecter cleaner might possible do it.
Old May 6, 2007 | 08:20 PM
littlebeardanny
i will get some injector cleaners and try it, also does the wires break down or not because i brought some after market wires from napa i check each one with omh meter and it check different on two of the wires.
Old May 6, 2007 | 11:46 PM
littlebeardanny
i put it end and look like it got worse.
