2000 Neon-5 Speed Stuck In Reverse
Old May 6, 2007 | 10:55 PM
NICK72's Avatar
NICK72
Default 2000 Neon-5 Speed Stuck In Reverse
Hello everybody! well my first post here is not a good one, so here it goes. I have a 2000 Dodge Neon, 5 speed. Today when I went to pull out of my parking spot I did so and in the process tried tp put it in 1st gear and I couldn't. The only thing it will do is go in reverse. The gears don't shift around like they normally should either. Is this a common problem with these? It has higher miles with 110,000 on it. It was running absolutely fine until this happend today. There was always a minor clunk when I put it in reverse but didn't think anything of it. Anyways, do you have any idea what copuld have happend? Thanks! [align=right][/align]
Old May 7, 2007 | 03:43 AM
Kapitald's Avatar
Kapitald
Default RE: 2000 Neon-5 Speed Stuck In Reverse
dont know what happened...but at that mileage you need to look into getting a new clutch and getting your transmission fluid changed.
Old May 7, 2007 | 05:34 PM
contagious19's Avatar
contagious19
well never happened to me but u might need a new clutch
Old May 7, 2007 | 05:38 PM
Biged83's Avatar
Biged83
i would have the shift linkage checked out
Old May 9, 2007 | 03:03 AM
master tech's Avatar
master tech
Site Moderator & Tech
Ck your shift cables at the transmission, there two cables and they have c-clips holding them into the brackets.
