p0508
Old May 10, 2007 | 05:00 PM
spikeymikey87's Avatar
spikeymikey87
Default p0508
p0508 what is it anyone?
thanks
Old May 10, 2007 | 05:29 PM
Fantasticle's Avatar
Fantasticle
Default RE: p0508
DTC P0508 is; Idle Air Control Circuit Low. Which means the Idle Air Control Circuit input is below acceptable limits. test the Idle Air Control (IAC) valve, the wiring between the IAC and the PCM and made sure the IAC passages in the throttle body are clean. If thats all good then the PCM probably needs to be replaced.
Old May 10, 2007 | 05:31 PM
spikeymikey87
Default RE: p0508
ok thanks. i just wanted to make sure i unplugged the right thing
Old May 10, 2007 | 05:36 PM
Kapitald's Avatar
Kapitald
Default RE: p0508
hahaha hes megasquirtin lol
Old May 10, 2007 | 05:58 PM
spikeymikey87
Default RE: p0508
that and pulling out my hair. my a/f are going crazy
Old May 10, 2007 | 06:21 PM
Kapitald's Avatar
Kapitald
Default RE: p0508
do you have the wideband o2 sensor....the AEM Uego gauge??
Old May 10, 2007 | 07:05 PM
spikeymikey87
Default RE: p0508
yup slightly fixed the problem still not good though. cant get it to crank over good. ad i dont really want to burn out my starter motor
Old May 10, 2007 | 07:23 PM
blackflame's Avatar
blackflame
Default RE: p0508
wow, what a project. I hope you get that running soon.
Old May 10, 2007 | 07:32 PM
tooslow's Avatar
tooslow
Default RE: p0508
Is your af is pulsing from lean too rich?
Old May 10, 2007 | 07:34 PM
spikeymikey87
Default RE: p0508
well i fixed the a/f problem. the problem was that i had ego correction on all the time, so it was trying to compensste for itself all the time, and therefore messing it up
