I'm looking for a dual exhaust for an 05 SXT. Recomendations?
Old May 11, 2007 | 03:42 PM
technical18's Avatar
technical18
Default RE: I'm looking for a dual exhaust for an 05 SXT. Recomendations?
ORIGINAL: Clokwerck
The Vibrant does? Or the Magnaflow? Or both hang lower on the one side? lol So many options....
lol i know...
yeah it looks like the backright side (viewing from the back forward) hangs lower on the Vibrant but im wonderingcan the pipe be bent up? or maybe a bracket fitted to pull it up higher?
Old May 11, 2007 | 03:45 PM
Clokwerck's Avatar
Clokwerck
Yeah it's probably possible, I could pull out the welder and make my own bracket to pull that side up. But if anything if the one side hangs lower and there is nothing I can do about it, I will more than likely go with a single exhaust, would rather not have my car look like the exhaust is gonna fall off at any moment lol.
Old May 11, 2007 | 04:38 PM
blackflame's Avatar
blackflame
I would go with magnaflow or borla. From what I have heard Borla is a little bit better but always cost more. Thats why I'm going with magnaflow.
Old May 11, 2007 | 05:01 PM
Clokwerck's Avatar
Clokwerck
Do you have to cut the bumper to make the magnaflow or borla fit?
Old May 11, 2007 | 05:02 PM
neon03se's Avatar
neon03se
the magnaflow fits with no mod but of course it would look better with cut out slots for the exhaust. the magnaflow is what i was referring to sticking out a lil more on the left
Old May 11, 2007 | 05:04 PM
Clokwerck's Avatar
Clokwerck
Meh, I can deal with a little further out, as long as it's out and not down? Again I could modify the hangers too if I had to.
Old May 11, 2007 | 05:09 PM
neon03se's Avatar
neon03se
well you might have to mod the hangers also cuz there is someone else here that has the magnaflow and its pretty much like mine, sticks out a lil but i think mine hangs just barely because i used to have a massive coffee can muffler on the left side well here's a pic you decide but like i said, i think its because i had a huge muffler if i didnt have it i think it would be ok.
Old May 11, 2007 | 05:10 PM
neon03se's Avatar
neon03se
sorry lol
[IMG]local://upfiles/57068/F8AEDD9129C9486BB2108A989DD374E4.jpg[/IMG]
Old May 11, 2007 | 05:12 PM
neon03se's Avatar
neon03se
as far as doing it yourself it is really easy, im sure the others are as well, just unbolt and remove old exhaust, and install and bolt up new exhaust. not one problem with the magnaflow but not sure bout borla or any others but like i said they should all be user friendly
Old May 11, 2007 | 05:14 PM
Clokwerck's Avatar
Clokwerck
It's not too bad, and yeah the previous muffler may have caused that but again I can probably just modify the hanger so it would sit higher if it's a problem. And I need to compliment you on the Megan suspension, have it on my Integra. Yeah the Magnaflow is a bolt up kit, easy to do, not a problem anyways I have a welder even if it wasn't bolt on. I bought it when I had to do the header on my Integra for turbo, at the time they didn't have a decent header for the turbo on my Integra, so I just fabricated one and it worked out really well.
