M/T won't go into reverse
Old May 20, 2007 | 09:15 PM
loocsissor's Avatar
loocsissor
Default M/T won't go into reverse
Last night, I backed out of my driveway and everything was fine. When I came home and went to back into my driveway, my transmission won't go into reverse. All forward gears work properly, just feels like there's a wall stopping me from getting it into reverse. When I get close, it pops me into 4th. Any ideas? BTW, it's a 2001 Neon R/T manual.
Thanks for any help!
Old May 20, 2007 | 10:24 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: M/T won't go into reverse
Check your shift linkages on your shifter and also on your tranny itself. I had one of my bushings on my shifter not completely pushed on it and I had a hell of a time putting it in 3rd gear. Just check and make sure bushings are in good shape and everything looks normal.
Old May 22, 2007 | 01:24 AM
Izero's Avatar
Izero
if they are still connected then try pushing the clutch down while giving it some gas and keep is at a steady rpm while trying to put it in and letting off the clutch very very very slowly.... make sure theres nothing behind you btw....
Old May 22, 2007 | 02:33 AM
LowSlowNeon
ORIGINAL: Izero
Why should he do that? WTF is that going to do? He can't physically get it to go into that gear so what difference is that going to make? Its one of two problems. 1.) something to do with his shift linkage or bushings either on the tranny or shifter itself or 2.) something internally in the tranny is busted.
Old May 22, 2007 | 04:51 AM
Izero's Avatar
Izero
lol yea well when u bring the engines revs up and let off the clutch as you are part of the way into gear you can force the trans to shift.... thats what thats going to do....... but if it isnt the bushings or the linkage then i'd say its the syncro.....
Old May 22, 2007 | 04:59 AM
lblackneon's Avatar
lblackneon
I'd say it's your shift cable. My car stopped going into reverse and that was my problem.
Old Oct 29, 2008 | 05:57 AM
Mofugga101's Avatar
Mofugga101
I have the same exact problem on my 2001 neon. I took off the center console and the linkage is busted. So I have to buy a new cable for about $130 from the dealer.
Old Nov 30, 2008 | 03:23 PM
hardrock086's Avatar
hardrock086
my car just did this today, the bushing which sits in the linkage to move the shift fork is gone. I am not sure if it is available seperately from the linkage, but will find out tomorrow
Old Nov 30, 2008 | 11:17 PM
Kath's Avatar
Kath
sounds like the linkage/cable.
if the synchro was shot, then what Izero said would be the way to work around it. once upon a time I had a geo metro, and reverse wasn't synchro'd at all in that car. it would sometimes refuse to go into reverse, and you had to do just what Izero said, kinda grind it into gear. It can sound scary, but some cars from many decades ago often worked this way. but... if your synchro isn't busted (unlikely for reverse), its probably linkage/cable.
hmm, i forget now, does the neon have a blocker which prevents shifting into reverse when your traveling forward at speed? I can't recall off the top of my head. if so, that could be what's broken too.
Old Nov 30, 2008 | 11:29 PM
InPsychOut's Avatar
InPsychOut
Check out THIS LINK for replacement bushings. While you're replacing one, you might as well do both at the shifter and both at the transmission. Easy job, and if one has gone, they probably all will soon enough. $22 I think for all 4 bushings shipped.
