headlights repair kit?
Old May 24, 2007 | 08:03 PM
867neon's Avatar
867neon
Default headlights repair kit?
does anyone know of any way to clean the headlights, cause mine are a lil' bit "foggy", and i'd like to make them look clear/new, i've seen/heard of kits that are sold at various advance auotoparts, autozone, and other 'remedies' to clean them. but i'd like to know if anyone in here actually knows which one works or which one would give me a better result.
thanks in advance
Old May 24, 2007 | 08:16 PM
contagious19's Avatar
contagious19
Default RE: headlights repair kit?
yea i would also like to kno mine r da same.
Old May 24, 2007 | 08:40 PM
blk94z28's Avatar
blk94z28
Mine are also, my dad cleaned his on his golf. Using like 1400grit sand paper and 1800grit(anywhere around there would be fine). Than using a buffer with polishing compound and they came out extremely clear. Only bad thing about this is it takes off whatever coating is applied to the headlights and after a year they will be foggy again but you just have to do this again. I was going to look into some kind of protectant or those headlight skins to try and make it last longer.
Old May 24, 2007 | 09:13 PM
mike9fore's Avatar
mike9fore
Toothpaste....That can do the trick...Take toothpaste dap some on a cloth and wipe it away....
Old May 25, 2007 | 03:54 AM
nswap7's Avatar
nswap7
iv seen the protectant, just cant remember where. If you see it, post the link please.
Old May 25, 2007 | 04:48 AM
Izero's Avatar
Izero
i am pretty sure they sell it at autozone.... and pepboys.... just go there and ask someone that works there.....
Old May 25, 2007 | 05:43 AM
neon03se's Avatar
neon03se
try Plastix, i believe it is made by meguiar (spelling) i use that stuff to polish my headlights and tail lights also the plastic that covers the gauges, comes out very very clean. try it out
Old May 25, 2007 | 04:50 PM
neon chic's Avatar
neon chic
platix will only work to get the grazing off headlights if theyre not that bad... i used plastix then took invisible glass and a microfiber towel to them it removed alot of the grazing from mine mine are really bad tho.
~also if u have a bladk car i HIGHLY recommend turtle wax's color magic wax in black its amazing!! they make it for other color cars too but most places only sell black~
Old May 25, 2007 | 05:05 PM
neon03se's Avatar
neon03se
it actually worked really good on my friends 350z headlights. he bought it used and the lights were really foggy and yellow, he used plastix on em and they came out looking almost new
