fuel pump ?....
Old May 29, 2007 | 01:50 AM
Acrfanatic's Avatar
Acrfanatic
Default fuel pump ?....
Ok so my car hasnt been starting correctly lately. I have to hold in my gas pedal and continue to pump it in order for it to start right. But anyway, my question is this: Could my car not starting right be caused by a fuel pump? If so am i able to just get a new fuel pump and things might be better than?
Old May 29, 2007 | 02:02 AM
lblackneon's Avatar
lblackneon
Default RE: fuel pump ?....
Are those the only mods u have on your car?
It's very possible that it's your fuel pump. Have you put any fuel cleaner in your car? How are the spark plugs and wires? When was the last time they've been replaced?
Old May 29, 2007 | 02:10 AM
Acrfanatic's Avatar
Acrfanatic
i dont know when the spark plugs and wires were changed...ill definately look into changing them...can you suggest certain plugs i should get and wires also...
Old May 29, 2007 | 02:18 AM
nswap7's Avatar
nswap7
For plugs- Champion or NGK Iridium
For wires- in my opinion, something like MSD or Mopar for original quality.
Old May 29, 2007 | 03:10 AM
lblackneon's Avatar
lblackneon
Accel spark plugs are good too.
Are u sure that u have to hit the gas to make the car start right?
Old May 29, 2007 | 03:54 AM
03neonRT's Avatar
03neonRT
I doubt its the fuel pump...if it were I would imagine you would have issues while the car was running as well, not just when you were trying to start it on occassion. I would check the plugs and wires...make sure none of the plugs are fouled and check the wires for corrosion...
I know I've probably asked this before, and you've probably posted it a dozen times, but what are the exact symptoms your Neon has?
