lower control arm help to get bolt out
Old Jun 3, 2007 | 11:03 PM
02BLACKR/t's Avatar
02BLACKR/t
Default lower control arm help to get bolt out
When i started taking my lower control arm off i noticed the back bolt was coming off hard. After a few tries of taking it off the nut inside the frame came loose. Now all it does is turn. How can i get to the nut to stop it from turning. It is the bolt by the stabilizer bar cosest to the rear of the car on the left front. Please i need help! Thank you
Old Jun 3, 2007 | 11:08 PM
02BLACKR/t's Avatar
02BLACKR/t
Default RE: lower control arm help to get bolt out
Does any one have any ideas or will i have to cut throught the frame?
Old Jun 3, 2007 | 11:13 PM
spikeymikey87's Avatar
spikeymikey87
well the bolt itself might have had splines on it to keep it from turning in the first place. you said it was hard, did it turn very little slowly, or not at all and then all at once. if it is all at once, you snapped the splines and thats not good.
Old Jun 3, 2007 | 11:25 PM
02BLACKR/t's Avatar
02BLACKR/t
a little at a time then it came loose. What do you think it is and how could i fix it.
Old Jun 3, 2007 | 11:26 PM
02BLACKR/t's Avatar
02BLACKR/t
the bolt is still in and will not come out.
Old Jun 4, 2007 | 12:00 AM
spikeymikey87
is it that the bolt just spins freely now and the nut isnt doing anything? are you trying to get it off or on
