interesting little bit of info about a/c and WOT
Old Jun 9, 2007 | 05:02 PM
spikeymikey87's Avatar
spikeymikey87
Default interesting little bit of info about a/c and WOT
well i have been reading a bit into the service manual so that i may be able to figure out my idle problem and i came across a little bit of info. [align=left]
When the PCM senses a wide-open-throttle condition through the Throttle Position Sensor (TPS) it deenergizes the A/C compressor clutch relay. This disables the air conditioning system and disables EGR (if equipped).
[/align][align=left][/align][align=left]so i guess when you drive around with the a/c on and you go WOT, you dont lose power after all[/align]
Old Jun 9, 2007 | 05:10 PM
Freerider's Avatar
Freerider
Default RE: interesting little bit of info about a/c and WOT
LIEZ!!!!!!!!!!
Old Jun 9, 2007 | 05:27 PM
Sawhiskey's Avatar
Sawhiskey
I think, I do notice a lose in power with WOT if the AC is on.
Old Jun 9, 2007 | 06:08 PM
LowSlowNeon's Avatar
LowSlowNeon
I knew it did that, but you still feels like it is sucking power.
Old Jun 9, 2007 | 08:17 PM
nswap7's Avatar
nswap7
i refuse to use the a/c
