Accelerator is hard to push. Any Ideas?
Old Jun 12, 2007 | 11:41 PM
wlf's Avatar
wlf
Default Accelerator is hard to push. Any Ideas?
New here and this is my first post, hope you can help.
I got my daughter a 2001 Neon 4 door 2.0 auto. The gas peddle is really firm. So much so that when you try to accelerate, it is hard to add just a little gas. It will resist and when you push harder, open suddenly too much.
I replaced the throttle cable and the Transmission kick down cable but it is still firm.
Any Ideas? Has anyone else had this problem?
I tried a search but no luck.
Thanks in advance.
Old Jun 13, 2007 | 12:06 AM
spikeymikey87's Avatar
spikeymikey87
Default RE: Accelerator is hard to push. Any Ideas?
this may sound kind of wierd, but it may be the way you are pressing the gas pedal itself. the pedal is a "comfort" pedal which means it will move on a hinge, and then you push it down also. try pushing it from only one place such as just the bottom and see if it is different
Old Jun 13, 2007 | 12:15 AM
wlf's Avatar
wlf
spikeymikey87,
Thanks for the reply.
Yea I have tried from every position. If you get high on the pedal then it is a bit easier but your heel is off the floor so this is real uncomfortable. I have had many cars and this is the hardest. Is the spring located in the throttle body? Is it a replaceable part?
Old Jun 13, 2007 | 12:17 AM
wlf's Avatar
wlf
This may sound funny but after you get past the first 1/2 inch, the pedal feels normal. It is the first 1/2 inch that seems to really resist moving.
Old Jun 13, 2007 | 02:41 AM
spikeymikey87
thats the same thing that i have, im pretty sure its just the pedal itself. i guess i just got used to it
Old Jun 13, 2007 | 02:49 AM
nswap7's Avatar
nswap7
mine does the same
Old Jun 13, 2007 | 03:08 AM
dhvaughan's Avatar
dhvaughan
check for this.... my ford explorer does that. where the throttle body plate closes up against the tb throat, it builds up some sticky gunk. every 3 months or so i have to remove the air cleaner and spray it out with carb or tb cleaner. when the gunk is there - once you kick it open its ok, but after you shut it off and it cools down it sticks again.
Old Jun 13, 2007 | 05:53 AM
nswap7's Avatar
nswap7
awesome info, ill have to try that in the morning
Old Jun 13, 2007 | 11:28 AM
wlf's Avatar
wlf
Thanks dhvaughan, I'll give that a try. My daughter does say it is worse when cold.
Old Jun 14, 2007 | 03:21 PM
wlf's Avatar
wlf
I did the fix last night. The throttle body on the 2ng generation is real easy to get to. I sprayed it wide open then started the car and sprayed as my daughter flicked the throttle. She drove for a while and says it is working much better and is no longer sticking. Time will tell. She took the car to school today and I will post after I talk to her this evening.
Thanks again.
