HOW TO DO:FLIP/FLOP TRUNK!!REVISED
Old Jun 16, 2007 | 10:46 PM
neon 05's Avatar
neon 05
Default HOW TO DO:FLIP/FLOP TRUNK!!REVISED
AIR WOLF THESE AINT YOUR INSTRUCTION BUT A BUDDY OF MINE IN L.A. SENT THEM TO ME !!
Flip Flop Trunk Modification
(slight variations with some years)
Tools Needed:
10mm Socket or open end wrench
Cut-off wheel or similar
Scissors
Sharpie Marker
Masking Tape
A nice Clean area
Small Silicone Tubing(optional)
Razor Blade(optional)
Lock-Pins(optional)
1. Using Sharpie Marker, Draw a ring around the head of all your stock bolts.
2. Using a 10mm socket or open end wrench, carefully remove all 4 stock bolts that hold your trunk on. Remember, once you get all the bolts out, there won't be anything holding your trunk, so having a buddy to help hold it is a good idea.
3. After removing the bolts and wire harness, Lay the trunk lid on a nice clean surface as to not scratch it all up.
4. If applicable, remove Trunk Lid Carpeting.
5. Now that carpeting is removed, Make your cut marks on the brackets with the Sharpie. Just follow up the sides as you see shown in the picture, and the top should be just above the top bolt hole location.
6. It is a good idea to go ahead and mask the area where you don't want to cut just to make sure you don't go crazy with the cutting.
7. Start Cutting.
8. When you are finished cutting, remove the masking tape and take a look at your work. If your lines are not straight, clean them up by trimming.
9. Repeat steps 5-8 on the other bracket.
10. Now that you are finished cutting, it's time to cut the carpet to match.
11. Cut the carpet to match the cuts you made on the brackets.
12. You will notice in the picture that this looks a little raw, and not very clean at all. This is where the Silicone hose and Razor Blade comes in handy.
Optional Steps
1. Split the hose down one side with the razor blade being careful not to cut yourself.
2. Route the split side of the hose around the cut edge of the bracket and carpet, and poof.....now it's a nice clean install.
Now for the flipping.......
Re-install the trunk lid, but only put in the top bolt on each bracket, then simply tilt your trunk lid down. Now wasn't that easy.
Right now, I'm using all 4 stock bolts when I don't want the trunk flipped, I just take out the bottom 2 when I'm at a show or whatever. If you want to, you can either find some lock pins that are the same size as the bolts and use them in the bottom holes, or you can just find a couple lock pins and drill holes for them.
This mod does take some playing around with to get your trunk to be flush with no gaps when it is closed unless you use all 4 stock bolts when you want to close it.
These are the basics, and enjoy your modding. By no means is this the only way to do this, but it is the best that I have figured out so far. If you do decide to do this mod, please be careful, and don't blame me if you screw something up....... Have Fun.
Old Jun 17, 2007 | 02:40 PM
AirWolf's Avatar
AirWolf
Default RE: HOW TO DO:FLIP/FLOP TRUNK!!REVISED
Well your a bit to late over 30 have gotten mine and done my flip flop trunk . That doesnt look to bad mines more custom .
Old Jun 17, 2007 | 06:20 PM
nswap7's Avatar
nswap7
well theres gunna be newbs who will do it, and prob wont care about "custom" as long as it looks good
Old Jun 17, 2007 | 06:40 PM
neon 05's Avatar
neon 05
custom?maybe if you put your pin idea airwolf probably but its simple you just needed to just need to break it down alittle in writting thats all..
Old Jun 17, 2007 | 07:47 PM
AirWolf's Avatar
AirWolf
ORIGINAL: nswap7
My husbands does look awesome and over a ton of guys and gals have done mine and still emailing me for my info and the pin thing is in the info and pics.
Old Jun 17, 2007 | 08:49 PM
nswap7's Avatar
nswap7
im not saying people wont ask you, just that others may use this. im not judging cuz i havnt read yours and compared it, but i didnt really care for the idea, but thats my opinion and has no effect on others opinions.
Old Jun 18, 2007 | 01:44 AM
AirWolf's Avatar
AirWolf
My husband looked this over and said his way is the simple and easy route and this style is harder and might ruin your trunk .
Old Jun 19, 2007 | 06:08 AM
neon 05's Avatar
neon 05
ruin in which way there no science in ruin the trunk, i just did it today wit a metal grinder and smooth the edges ill post pics later tomorrow.. , all that is done is cuting the center piece off and rerouting the bottom bolt to custom or old fashion rachet
Old Jun 19, 2007 | 03:52 PM
AirWolf's Avatar
AirWolf
Still his is harder than my husbands. My husbands only has a few steps and alot more pics much easier all Im saying plus I had mine on here 1st and longer.
Old Jun 19, 2007 | 04:01 PM
neon 05's Avatar
neon 05
airwolf i know you did but when your not on people want to get a quick look and get a idea, isnt that bad of a mod to do ...if you notice thats y i wrote on the top of my thread a dedication to you..
