Why don't my 18"s fit on my '04 SXT??
Old Jun 27, 2007 | 02:17 PM
  #21
demonbasketball04's Avatar
demonbasketball04
Default RE: Why don't my 18"s fit on my '04 SXT??
ORIGINAL: nswap7
yes..needs pics man. are the tires all the same brand and replaced at the same time??
Yeah, all same brand, none have been replaced yet though.
ORIGINAL: 03neonRT
You need to get new struts if you want to stick with that tire/wheel combination since your rubbing against the spring perch...the Tokico HP Blues should work nicely for you.
What do these run?! I'm afraid to even ask at this point.
Now onto the pic...
[IMG]local://upfiles/61535/A3C5CF23EDB34A19A5BD0E02461B8DEB.jpg[/IMG]
Old Jun 27, 2007 | 02:49 PM
  #22
masterofdisaster127's Avatar
masterofdisaster127
I have a set of 17's in my basement, Borbet Rims (one rim has a slight bend but still holds air fine) with Kumho ASX tires....got them off of tire rack if anyone's interested.[/align][/align]Personally, I'd try and unload the set you got and go with a set of 17's....[/align]
Old Jun 27, 2007 | 03:33 PM
  #23
03neonRT's Avatar
03neonRT
ORIGINAL: demonbasketball04
ORIGINAL: 03neonRT
They sell on Ebay for $255 shipped brand new, or if you purchase the Tokico lowering springs with the struts it goes to $300 I think.
Old Jun 27, 2007 | 03:52 PM
  #24
demonbasketball04
Lowering springs?! Wouldn't that just make my situation worse?!
Old Jun 27, 2007 | 04:08 PM
  #25
03neonRT's Avatar
03neonRT
No.
Old Jun 27, 2007 | 04:16 PM
  #26
AirWolf's Avatar
AirWolf
Yeah a drop would help you out greatly and the tokiko springs and strut kit off of ebay is the way to go.
Old Jun 27, 2007 | 09:13 PM
  #27
demonbasketball04
I'm a little lost on the lowering springs situtaion.
Can someone elaborate on it for me please??
Old Jun 27, 2007 | 09:28 PM
  #28
03neonRT's Avatar
03neonRT
The problem your having is your tires are rubbing against the spring perch, which is stationary on the strut no matter what type of spring or how much drop you have. The Tokico HP Blues has a higher strut perch then the stock Neon, so it will allow you to run those wider tires...when you add lowering springs the only thing that gets lowered is the car, the strut perch and strut will still be at the same height.
Old Jun 28, 2007 | 06:07 PM
  #29
Midnight SRT's Avatar
Midnight SRT
Nightly Creeper
You definitely don't want them to rub, I had the same problem a while back but only had that set of wheels. It was hell.
