question about a amp
Old Jul 2, 2007 | 11:05 PM
twk62390's Avatar
twk62390
Default question about a amp
i kno this isnt the audio forum but i kinda need sum help fast and you guys are the best so im hoping i get help.
i got a hifonics brutus 2000 watt amp and i have every thing hooked up right as far as i kno. ive hooked up quite a few systems.
but i am not getting any sound but i am getting power. the protection light is not comming on so im guessing everything is good and ive checked all the fuses, any ideas?
thanks
Old Jul 2, 2007 | 11:06 PM
contagious19's Avatar
contagious19
Default RE: question about a amp
u sure da subs r connected right
Old Jul 2, 2007 | 11:09 PM
twk62390's Avatar
twk62390
yea. i had i kicker amp hooked up and everything worked so i just switched over to my new amp and now i dont have sound. but i checked the speaker wires and all that so im wondering if the amp is bad
Old Jul 4, 2007 | 06:22 PM
contagious19
yea mayb da amp is bad. did u check da fuses for da amp? or da one by da battery?
Old Jul 4, 2007 | 11:58 PM
twk62390's Avatar
twk62390
yea. i couldnt figure it out so i took it to the shop for them to test and tell me if its bad or not
Old Jul 5, 2007 | 05:28 PM
Kapitald's Avatar
Kapitald
well if it has power its not the fuses........you have power but no thump....trace your speaker wires all the way from subs to amp make sure they arent grounded or shorted to anything...check your RCA cables because if thats not hooked up you wont get any sound either....you should check behind the cd player as they rarely come unplugged but sometimes do......when all is said and done take another speaker of any kind (doesnt have to be a sub...if its a speaker just turn the amp level down) and check to see if you can get any other speakers to play off of it......what ohm load are you pulling off of the amp...4 ohm?? 2 ohm?? 8 ohm??? is the amp a 2 channel 4 channel or a monoblock>??
