Tire question
Old Jul 8, 2007 | 05:00 PM
05HermieSXT's Avatar
05HermieSXT
Default Tire question
Okay so I know little about tires and I know the stock is a 185/60/R15 for an 05 SXT. Question I have is will a 195/60/R15 fit on the stock rim? Walmart doesnt carry the 185's but do have the 195's. Just wondering.
Old Jul 8, 2007 | 05:30 PM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Default RE: Tire question
ORIGINAL: 05HermieSXT
Yep, it sure will....
The way to explain tire sizes are as follows.... 195/60/R15
195 = Width of the tire in millimeters
60= This tells you how tall the tire is in regards to the width. Basically, it just tells you how tall or low profile the tire is...
R15= This is the diameter of the actual wheel itself...
Basically, going to a 195 is just a slightly wider tire......and you can run these with no problem.
*edit*
Forgot to mention that by changing tothat taller tire, you're speedo will be off and you'll be going roughly 2mph faster then what it actually reads...
Old Jul 8, 2007 | 05:35 PM
j_son600's Avatar
j_son600
195/60/R15's are what I have on my stock wheels and they worked fine.
Old Jul 8, 2007 | 07:47 PM
ewetho's Avatar
ewetho
According to BFG you could put a 205/55R15 tire on that rim which would be almost spot on for the speedo.
Old Jul 9, 2007 | 05:29 AM
05HermieSXT
which explains why im going 3 MPH slower then whats its reading.
