Is this a COMPLETE turbo kit??
Old Jul 10, 2007 | 12:14 AM
neon03se's Avatar
neon03se
Default Is this a COMPLETE turbo kit??
hey guys i was just browsing around on ebay and came up on this "kit", it says its for a 03-05 dodge neon, just wanted to know your thoughts on it, is it everything one would need to complete their turbo set up? Here's the link.......http://cgi.ebay.com/ebaymotors/dodge...QQcmdZViewItem
Old Jul 10, 2007 | 01:39 AM
03neonRT's Avatar
03neonRT
Default RE: Is this a COMPLETE turbo kit??
The things that jump out at me that are missing is a FPR, return line, and parts to tap the oil pan...
Old Jul 10, 2007 | 01:52 AM
neon03se's Avatar
neon03se
how much would i be looking to spend extra for those items? other than that what else would you say RT
Old Jul 10, 2007 | 01:57 AM
03neonRT's Avatar
03neonRT
Well...a good RRFPR is going to be around $250-$300 new, and a return line kit will cost you $200 unless you DIY with the Spoolboy mod. The fittings to tap the oil pan shouldnt be more then $20 or so...
As for other things that may be missing...I cant really find anything else except for maybe a Missing Link or Map Clamp. Your still better off going with MS for fuel management though with NGC...
Old Jul 10, 2007 | 02:14 AM
neon03se's Avatar
neon03se
all in all would you say this is a good buy? also what brand turbo is it or does it even matter
Old Jul 10, 2007 | 02:20 AM
03neonRT's Avatar
03neonRT
For $1k, I would say its a good buy...as for the turbochargers brand, I couldnt say but its a 15g which is the same size as the SRT-4's TD04 (and it looks VERY similar as well, but its obviously NOT a Dodge TD04). A small turbo, with a fast spool, and perfect for a stock bottom end. I so go for it...
Old Jul 10, 2007 | 11:29 AM
Adionik's Avatar
Adionik
I saw some guy on 2gn blow a hole in his oil pan and almost ruin his engine just boosting at 5 psi. I'm pretty sure the engine wasn't completely stock either.
Just be careful...
Old Jul 10, 2007 | 11:31 AM
03neonRT's Avatar
03neonRT
ORIGINAL: Adionik
Just be careful...
That was from a bad fuel tune.
neon03se's Avatar
neon03se
im thinking about getting it but would you trust the turbo from ebay. or would you go with a complete hahn kit?
Old Jul 10, 2007 | 11:37 AM
03neonRT's Avatar
03neonRT
If you have the money buy a complete Hahn kit...if you dont have the money buy this partial kit or piece together an SRT kit.
