fuel
Old Jul 12, 2007 | 10:29 PM
blazing03neonR/T's Avatar
blazing03neonR/T
Default RE: fuel
i thought which was right that you use pre on all high out put car right and rt have the sohc ho right magnum
Old Jul 12, 2007 | 10:53 PM
Adionik's Avatar
Adionik
Default RE: fuel
I am averaging 16mpg.
W.T.F
I am throwing evap codes and it is NOT my gascap, so could this be the culprit? NEW SPARK PLUGS? HELP ME!!!
Old Jul 13, 2007 | 12:36 AM
lblackneon's Avatar
lblackneon
Default RE: fuel
The type of fuel that needs to be used just depends on the engine. My dads Mustang GT doensn't require 93.
Old Jul 13, 2007 | 02:52 AM
yellowO3r/t's Avatar
yellowO3r/t
Default RE: fuel
it is not required for the neon r/t but "recommended" it says it in our manual and when you open the gas cap.
Old Jul 13, 2007 | 03:35 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: fuel
ORIGINAL: Adionik
W.T.F
how old are your plugs/wires. you also might run a tank of cleaner through.
and stop and go <30 mph all the time, my peon gets high 20s.
87 is all I use. I feel using the higher test would just be a waste.
Old Jul 13, 2007 | 01:26 PM
contagious19's Avatar
contagious19
Default RE: fuel
i use 87 and i only use Shell or Chevron nutin else
Old Jul 13, 2007 | 02:05 PM
Adionik's Avatar
Adionik
Default RE: fuel
ORIGINAL: flamingpinhead
ORIGINAL: Adionik
W.T.F
My wires are brand new. I got them in Feb. But my sparks...I have no idea. I should just get some cheapies right? I do a LOT of in city driving...so i guess that's why it's so bad. Along with my heavy *** 17's. [&:]
Thanks!
Old Jul 13, 2007 | 03:49 PM
03neonRT's Avatar
03neonRT
Default RE: fuel
ORIGINAL: Adionik
ORIGINAL: Adionik
W.T.F
Thanks!
Haha those SRT-4 wheels are heavy as hell for a 6" wide wheel (21 lb each and 41 lb with stock tires!!!)...but they shouldnt be having that much affect on your gas mileage...
Old Jul 13, 2007 | 04:26 PM
Adionik's Avatar
Adionik
Default RE: fuel
Yes but will new sparks really make that much of a difference on my mpg? I might get some of that gas tank cleaner.
Old Jul 13, 2007 | 06:05 PM
03neonRT's Avatar
03neonRT
Default RE: fuel
Pull out a spark plug and see what it looks like...if they are really bad they could be causing your poor fuel economy...
As far as the fuel system cleaner goes, its a waste of money because modern gasoline hasA TON of fuel additives and detergents already in the fuel.
