can i use thies?
Old Jul 16, 2007 | 11:02 AM
NHARINTON's Avatar
NHARINTON
Default can i use thies?
i have a 2003 Neon Se, W/ Tokico HP Blues. Thies are off a Srt-4, can i use them??
i belive they are Tension Struts?
[IMG]local://upfiles/24713/E5CF8144FF7D4052BD55AAD8A519D15B.jpg[/IMG]
Old Jul 16, 2007 | 12:24 PM
03neonRT's Avatar
03neonRT
Default RE: can i use thies?
Yes you can use the aftermarket SRT tension struts on our cars.
Old Jul 16, 2007 | 12:33 PM
NHARINTON's Avatar
NHARINTON
cool thanks, im kind off a noob on suspension.... dont really know what they do.... how much of a diffrence will adding thies and a rear sway from an srt to my se make?
Old Jul 16, 2007 | 01:05 PM
03neonRT's Avatar
03neonRT
You wont really feel anything until you hit the brakes at a higher speed, it really jelps keep things "stable" under heavy braking like that. The SRT-4 rear sway bar is only 17mm, so it wont be a huge difference, but you'll definitely feel a difference with a rear sway bar compared to not having a rear sway bar.
Old Jul 16, 2007 | 01:08 PM
NHARINTON's Avatar
NHARINTON
cool thats what i wanted to know, for 60 bucks for all of it i think i will go for it.....
the neon will never be that fast, so i might as well make if a fun canyon car right!!
Old Jul 16, 2007 | 01:19 PM
Adionik's Avatar
Adionik
So what like you can take turns better? I might pick one up than. I need some cheap mods damnit![&:]
Old Jul 16, 2007 | 01:32 PM
NHARINTON's Avatar
NHARINTON
from what i understand, the sways will help body roll... making you turn better... and the rear tensioners help with front to bake body roll during braking, making the car more stable when braking into a corner....... so yeah turning should be much better!!
Old Jul 16, 2007 | 02:14 PM
Adionik's Avatar
Adionik
bad on struts i'd imagine
Old Jul 16, 2007 | 02:34 PM
03neonRT's Avatar
03neonRT
ORIGINAL: NHARINTON
Correct.
Sway bars are problaby the best suspesnion mod for the money...
Old Jul 16, 2007 | 02:41 PM
NHARINTON's Avatar
NHARINTON
ORIGINAL: Adionik
good on them i'd imagine..... less body roll means less pressure onthe strut.
