Gauge Pod wiring?
RE: Gauge Pod wiring?
Hello Guys.. the Gauges should be in for the weekend so i hopefully get them installed on the weekend..
I need to know where to run the vacume line to? I know u guys say a vac line in the engine.. but i dont know where there is one or what to look for..
I also need to know what wire is the O2 sensor and where i can find it and just splice into it?
well i have delayed long enough and had some time this weekend.. so i went out and did the install my self.. the volt gauge works 100%.. they are all GlowShift tinted series gauges..
i have all the others hooked up except for the air/fuel (i need to find out where to run the signal wire to under the hood).. and i need a picture of a vacuum line where i can run the line to for that gauge..
Please help me out..
Thanks a lot guys!
Thanks a lot guys!
im gonna make this simple for you and the a/f gauge install here is a link to a how-to that i just used... and ill have pics and possibly a vid of mine working in the AM.... good luck: http://forum.2gn.org/viewtopic.php?t=14653
THIS HOW-TO WILL NOT WORK FOR 03+ MODELS IT SAYS THOUGH SO JUST A HEADS UP!
and and just a sidenote..... BE VERY VERY VERY VERY VERY CARFUL TAKING OFF THE A-PILLARS I BROKE THE CLIPS ON ONE OF MINE..... hahahaha good luck and hope that link helps
