header
Old Jul 26, 2007 | 08:21 PM
03neonRT's Avatar
03neonRT
Default RE: header
No, you wouldnt be cutting into the header, you would be cutting off part of the midpipe...
Old Jul 26, 2007 | 08:34 PM
neon03se's Avatar
neon03se
Default RE: header
will that affect performance gains at all, (running it with a cat.)
Old Jul 26, 2007 | 08:42 PM
03neonRT's Avatar
03neonRT
Default RE: header
Slightly, but nothing you would ever notice on the butt dyno or the real dyno...
Old Jul 26, 2007 | 09:01 PM
neon03se's Avatar
neon03se
Default RE: header
so then the statement made on the MP website can be disregarded because it CAN be made to work with the catalytic converters.... and it will still perform better than short tube headers...correct?
Old Jul 26, 2007 | 09:39 PM
03neonRT's Avatar
03neonRT
Default RE: header
Correct.
Old Jul 26, 2007 | 10:11 PM
Adionik's Avatar
Adionik
Default RE: header
I think i wanna get one. But i wanna keep my cat
Old Jul 27, 2007 | 12:45 AM
neon03se's Avatar
neon03se
Default RE: header
you can keep your cat....
"its just a matter of cutting a little section from the midpipe right after the header and putting the cat in..."-03neonRT
one other quick question RT, maybe its a dumb one, but would the second 02 Sensor reach the cat in that case without anything else needing to be done.....
Old Jul 27, 2007 | 12:48 AM
03neonRT's Avatar
03neonRT
Default RE: header
You would need to extend the wiring for the downstream O2 sensor...and by "little section", I mean however long the cat is. I wouldnt recommend doing it yourself either...
Old Jul 27, 2007 | 01:40 AM
neon03se's Avatar
neon03se
Default RE: header
o definately not, just curious because i know one day someone will have the same questions....
Old Jul 27, 2007 | 03:02 AM
lblackneon's Avatar
lblackneon
Default RE: header
When i got my mpx lth I also purchased a vibrant ultra high flow cat but i ended up sending it back. the car sounds good without the cat imo (at least with my mods). the guy recommended the vibrant cat b/c it's really small and would be a perfect combination with the lth.
