Hurst short shifter
Old Jul 26, 2007 | 07:33 PM
ratam82's Avatar
ratam82
Default Hurst short shifter
Is it all that difficult, and if i were to take it to a mecanic what would be a reasonable price to pay?
Old Jul 26, 2007 | 08:04 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Hurst short shifter
installing a new shifter is madd easy
pretty much remove the shift ****,a few screws holding the console in place, then pry the shift cables off the shifter. the shifter is held in place by 4 bolts, unbolt the shifter, install the new one in reverse order. less than an hour job.
i would also reccomend upgrading the bushings, just replace them while changing the shifter. then the ones under the hood you can either go and remove the airbox and battery or try to get to them from below (youll save some hassle removing the airbox and battery)
how-to link: http://forum.2gn.org/viewtopic.php?t=6903
Old Jul 27, 2007 | 01:40 PM
vieirart's Avatar
vieirart
wats up its not worth havin a shop put in the shifter your gonna spend proally close to as much as u payed for it its an easy job it should have came with instructions that shows you.
