can ngk LZTR5A-13 work in a neon se
Old Aug 1, 2007 | 08:44 AM
agmurchison02's Avatar
agmurchison02
Default can ngk LZTR5A-13 work in a neon se
Hi, I'm new to doing my own engine work and other maintenance. Ineed new spark plugs andI'm wonderingifNGK LZTR5A-13will work in myNeon SE. My gap is 0.35 and the NGK is at 0.52. I'm staying away from platinum plugs cause last year I had a misfire and had to get a new ignition coil. Along with the NGK plugs I'm thinking about getting Magnecore plug wires, what do you think? Any advice is great, thanks.
Old Aug 1, 2007 | 03:22 PM
contagious19's Avatar
contagious19
Default RE: can ngk LZTR5A-13 work in a neon se
champions are good and da magnecore plug wires should be alright.
Old Aug 1, 2007 | 03:24 PM
03neonRT's Avatar
03neonRT
Not sure on that part number, but the NGK iridium spark plugs will work on the Neon...and they need to be gapped to around .035-.040...
