header question
Old Aug 3, 2007 | 01:42 PM
Adionik's Avatar
Adionik
Default RE: header question
Since a lot of my midpipe was cut for my glasspack, will I even have any room to keep my cat and an LTH? I'm going to get an LTH but that glasspack is freaking huge.
Old Aug 3, 2007 | 06:18 PM
03neonRT's Avatar
03neonRT
ORIGINAL: Adionik
Since you have a glasspack already you probably would be fine without a cat since the glasspack should quiet down the "raspy" tone that often comes with an LTH.
Old Aug 3, 2007 | 06:22 PM
Adionik's Avatar
Adionik
But you think i'll have enough room to keep it just incase?[&:]
Old Aug 3, 2007 | 06:29 PM
03neonRT's Avatar
03neonRT
ORIGINAL: Adionik
You should...I guess it depends where on the midpipe the glasspack was installed...
Old Aug 3, 2007 | 08:29 PM
dodgeneonz's Avatar
dodgeneonz
hey, is it possible to install the LTH yourself? is the welding part of the cat the only section that requires professional installation? Because if that's the case i'll rather install the LTH myself and then maybe (is it even possible) drive my neon over to the muffler shop to have them weld it on for me... that way it might only cost 30 or 40 dollars... is that possible? semester's starting and i'll be getting some $$ from uncle sam So i wanted to get as much info as possible and get it done asap.
Old Aug 3, 2007 | 08:33 PM
03neonRT's Avatar
03neonRT
Yes, you CAN install the LTH yourself...and you'll be able to drive it with no problem, it'll just be raspy and you probably wouldnt want to do too many WOT's around town...
Old Aug 3, 2007 | 11:24 PM
Somethingdirty's Avatar
Somethingdirty
Just remember that shops don't remove cats.
