header question
Old Aug 3, 2007 | 12:15 PM
metsj373's Avatar
metsj373
Default header question
anyone who has aftermarket headers how much horsepower increase do you get about and what site did u guys order it
Old Aug 3, 2007 | 12:48 PM
lblackneon's Avatar
lblackneon
Default RE: header question
The hp increase depends what u have done to your engine. Every mod helps to benefit another.
Old Aug 3, 2007 | 01:07 PM
metsj373's Avatar
metsj373
all i have is a cai how much horsepower u think the headers will give and wats the labor on installing headers
03neonRT's Avatar
03neonRT
The only header that will give you noticable gains on an R/T is a long tube header. The best brand available is the MPx LTH... available at ModernPerformance.com.
Old Aug 3, 2007 | 01:16 PM
metsj373's Avatar
metsj373
how mush horsepower increase?
Old Aug 3, 2007 | 01:25 PM
03neonRT's Avatar
03neonRT
Ehh on stock everything else, you'll probably see a strong 5-7whp increase, which is very good...
Old Aug 3, 2007 | 01:28 PM
metsj373's Avatar
metsj373
also how much u think labor is on that cause dont you have to drop the engine if u dont is it easy to install
Old Aug 3, 2007 | 01:31 PM
03neonRT's Avatar
03neonRT
No, you definitely dont have to drop the engine to change your exhaust header. Your going to have to remove the cat, and if you still want the cat, then have an exhaust shop cut out a small portion of the midpipe and weld the new cat back in (I would highly suggest keeping the cat). Labor for installing an LTH will probably run you $100-$200 depending on the shops hourly labor charge...
Old Aug 3, 2007 | 01:33 PM
metsj373's Avatar
metsj373
also your comp400cam how much was that cause i want to get the headers then that at the same time and c the increase
Old Aug 3, 2007 | 01:34 PM
03neonRT's Avatar
03neonRT
The Comp 400 was around $250.00...
