Today it was really bad. It probably went almost a mile on the freeway in 3rd. I can tell because the RPMs are really high...almost 2500 at 50 mph. Rediculous! I do 60 at 2300ish!
One thing you can try is to see if you can reset your PCM. Dosconnect your (-) battery temintal for about 30 min. then reconnect it. You PCM is prob having a hard getting used to the new temperatures and is still trying to use the plder warmer temperatures as a ferrerance therefore preventing your solenoid prom chaning the pressures in your tranny.
