Lowering Spring Help
Old Aug 5, 2007 | 02:39 PM
eaks's Avatar
eaks
Default Lowering Spring Help
Hey guys.. i just recieved my lowering springs late last week and attempted to install them (which was a complete pain).. the impact gun messed up and we just had a hard time doing it all.. only got the front to springs on and ran outta time.. i returned the spring compressors and will need to rent them again next weekend..
But on the fronts.. im hearing a clunking noise when i drive.. so i pop open my hood and push down on the car and stuff.. with a lot of pressure i find that the nut seems to come up and then come back down and hit on the metal under the hood (where the top of the strut assembly is connected).. i tried to tighten the nut while on.. but as u know when u turn the nut the whole strut turns..
So my question is how can i tighten the nut at the top of the strust assembly without remove the whole assembly again? as well how tight do i need to tighten the nut? im pretty sure we only tightend it to where it was on with the stock springs (which i didn't think about until after i was gone and returned the compressors)
Thanks
Old Aug 5, 2007 | 02:41 PM
contagious19's Avatar
contagious19
Default RE: Lowering Spring Help
i had da same problem and i believe it was a loose bushing from da strut
Old Aug 5, 2007 | 02:46 PM
eaks's Avatar
eaks
Im pretty sure its just that the nut isn't tight enough..
Old Aug 5, 2007 | 03:44 PM
03neonRT's Avatar
03neonRT
Yes, the clunking is because the top nut is not tight enough.
All you need is this little DIY tool...(21mm 1/2" drive socket with a 19mm socket and extenson)
Or this one...
Old Aug 5, 2007 | 05:25 PM
eaks's Avatar
eaks
haha.. Thanks man.. i saw the tool being used and i couldn't figure out what size it was.. finally got the suspenson in the front all adjusted correctly.. doesn't look like its an inch and a half on the threads tho..
oh well..
Old Aug 5, 2007 | 06:20 PM
Yako's Avatar
Yako
what kind of springs did u get?i dont kno that much but i heard that when u get new srpings u should get new struts too cuz the new springs could wearout the struts faster anyone correct me?
Old Aug 5, 2007 | 06:58 PM
eaks's Avatar
eaks
used the Kazera drop spings form TireRack.. haha.. $49.50 springs come to over $160 after shipping and customs and everything.. haha.. gotta love the boarder eh!
