INDY air
Old Aug 6, 2007 | 12:26 PM
PICKLEZ's Avatar
PICKLEZ
Default INDY air
I am thinking about buying a INDY air intake manifold but dont know what I need. I know the kit comes with everythink it needs but what about the throttle body? do I need to replace the remote one I have or will it work with the INDY? Should I even buy and INDY? Is it any good?
Old Aug 6, 2007 | 12:29 PM
AirWolf's Avatar
AirWolf
Default RE: INDY air
I had one and worked nicely for me but I also had a 60 mm tb and a ton of other mods before I took them out for the srt swap pretty soon. Yeah a tb would add to the indy manifold nicely.
Old Aug 6, 2007 | 12:30 PM
PICKLEZ's Avatar
PICKLEZ
but will my stock remote work with it?
Old Aug 6, 2007 | 12:53 PM
lblackneon's Avatar
lblackneon
A 60 mm TB will not help unless u have several mods to compliment it. First off, what mods do u have on your car Picklez?
2nd: The Indy Intake Manifold does not come with everything u need to install it. U have to customize a gasket to connect it to the head and I think it also needs a few screws if I remember correctly. I had a mechanic of mine install it and it's not an easy bolt on.
What remote are u talking about?
Old Aug 6, 2007 | 01:05 PM
Adionik's Avatar
Adionik
I have a 60mm TB i got from Joe...and im' damn stock with almost no mods.
Yet you will feel a hell of a throttle difference and the car pulls a little harder. But yeah, you have to get a lot more mods to really make a difference.
Old Aug 6, 2007 | 01:53 PM
lblackneon's Avatar
lblackneon
I would think that u lost bottom end and gained a bit in top.
Old Aug 6, 2007 | 02:13 PM
AirWolf's Avatar
AirWolf
I had a ton of mods to go with my indy and 60mm tb . yeah what remote are you talkin about never heard of a stock remote other than the remote to get inside and a remote car started which Im getting before winter.
Old Aug 6, 2007 | 08:13 PM
PICKLEZ's Avatar
PICKLEZ
so the stock throttle body on my 200 2.0 will not work with the indy? The indy kit I was looking at hass all the gaskets bolts and screws and says it will directly bolt to my 2.0 SOHC head but im not buying ti there must be more to it than that.
Old Aug 6, 2007 | 08:41 PM
lblackneon's Avatar
lblackneon
Where were u planning on buying it?
Old Aug 6, 2007 | 09:01 PM
ewetho's Avatar
ewetho
To get the most out of that intake manifold you need headwork and cams
