Need a "how to"
Old Aug 6, 2007 | 11:07 PM
Kapitald's Avatar
Kapitald
Default Need a "how to"
I need a "how to" on how to remove the power steering pump and a/c from a 04 mtx sxt.......
also...I had links for somebody on here that did alot of custom work...built custom intake manifolds and also alot of porting and headwork....was it all-motor-mike????? I would like to know who that was again thanks....
Any help appreciated...
Old Aug 6, 2007 | 11:32 PM
Kapitald's Avatar
Kapitald
Default RE: Need a "how to"
bump yo
Old Aug 7, 2007 | 06:15 PM
contagious19's Avatar
contagious19
well i know how to take off a powersteering pump but i dont kno about a/c. its only like 4 bolts.
well for da pump u need a 12mm socket, 13mm socket and small extension if sockets are small and the ratchet.
by da pulley there are 3 bolts (dont remember if its 12 or 13mm) well rotate da powersterring pulley so u can useda holes from da pulley to get to da bolts. once u loosen those bolts there is one more on da right side by da intake manifold, its da 13 or da 12 (dont remember). and den use a 3/4 wrench to losen da metal line for da fluid. and everyting should come out
Old Aug 8, 2007 | 02:46 AM
Kapitald's Avatar
Kapitald
would i need a smaller belt after that..or do i need one of those idler pulleys??
Old Aug 8, 2007 | 05:52 PM
contagious19
wat exactly are u trying to do?
Old Aug 8, 2007 | 06:19 PM
GrApHite03's Avatar
GrApHite03
Kapitald, PM me your e-mail address
