Sentry....any way to bypass?
Old Aug 8, 2007 | 07:24 PM
neon03se's Avatar
neon03se
Default Sentry....any way to bypass?
Is there any way possible to bypass the sentry on our cars other than going to the dealer? I only have one key that I got from the stealership and I'm afraid if i lose it, I'll be screwed.....don't really wanna pay the stealership for another one as i know i will get ripped lol
Old Aug 8, 2007 | 07:32 PM
GrApHite03's Avatar
GrApHite03
Default RE: Sentry....any way to bypass?
nope... can't do it. The FSM says to use the "Customer Learn" Mode you need two valid keys already programmed. This prevents you from buying a key and doing it yourself. Its dealer or nothing...
k3v
Old Aug 8, 2007 | 07:34 PM
neon03se's Avatar
neon03se
lol damn. this goes back to my cluster, i have the day off today and tomorrow and am gonna try to install it again. is there anything else you can think of that would cause the cluster not to work? i'm not even sure its the sentry just trying to figure this damn problem out. could my "aftermarket" alarm be the cause?
Old Aug 8, 2007 | 07:35 PM
dodgeneonz's Avatar
dodgeneonz
I got a bypass module from www.commandocaralarms.com but to be honest, you can make one yourself except i'm lazy ... basically what it does is that it requires you to have your key in your car at all times i hide mine somewhere around (not telling) so that the wires basically connects your key's chip to the ignition and you can just use a regular key. Make sure you put your sentry key somewhere where you need to open a few screws to get access to... otherwise someone can just come in and pull your key out and drive it away. another way is to basically cut the key off from the chip so that you only have the chip... that way if someone do find a way to get to your hidden sentry key then they only have the chip but not the key itself. I have one in mine so that i can remote start my car.
Old Aug 8, 2007 | 07:38 PM
dodgeneonz's Avatar
dodgeneonz
how's your cluster not working? like it's not lighting up at all?
Old Aug 8, 2007 | 07:49 PM
neon03se's Avatar
neon03se
well see it lights up and all when i put the key to the "ON" position, then when i try to start the car all electrical **** turns off.....maybe you can help me, im willing to go outside and take the damn thing apart if you have any suggestions that way maybe ill get a solution
Old Aug 8, 2007 | 07:54 PM
GrApHite03's Avatar
GrApHite03
ORIGINAL: neon03se
If it is that same cluster you posted about, i still think its junk... If you cluster works fine there is no reason why the other won't work. the only think stored in the cluster is the milage, nothing else... no sentry no nothing. As mentioned the before the cluster looks for a signal whether or not to illuminate the sentry light, but will have no effect on the car starting.
k3v
Old Aug 8, 2007 | 07:59 PM
neon03se's Avatar
neon03se
that i didn't know lol. so then regardless of what key i have, the damn thing should work right? it doesnt matter that on my original cluster that works, the sentry light turns on briefly then turns off while in the "ON" position, and on the white gauge cluster, it just blinks when the key is in the "ON" position
Old Aug 8, 2007 | 11:36 PM
neon03se's Avatar
neon03se
bump
Old Aug 8, 2007 | 11:52 PM
GrApHite03's Avatar
GrApHite03
ORIGINAL: neon03se
yes and no... yes to the cluster, no to the car running The cluster doesn't care wich key you use, the computer does.
ORIGINAL: neon03se
This is weird to me... I got to run to help my boy with is sylvia. I'll look again at the FSM when i get back and post.
k3v
