no bus error code
Old Aug 13, 2007 | 12:23 AM
jeremywearsvans's Avatar
jeremywearsvans
Default no bus error code
recently I was driving home and noticed my speedometer was jumping between zero and 120 mph, my temp gauge pegged as high as it could along with my fuel gauge and my tach went completely around and is now stuck on the bottom side of the pin.
when I turned the car off the red light came on and the odometer said "No Bus"
Im just curious if anyone has ever had this happen and what I could do to fix it. Im looking for an inexpensive fix because its an 02 neon with 165,000 miles on it so even though I would love to put a million miles on it because it runs like a top unfortunately I know it wont last that long.
thanks,
Jeremy
Old Aug 13, 2007 | 12:57 AM
Rodge57's Avatar
Rodge57
Default RE: no bus error code
Check this out
Old Aug 13, 2007 | 12:58 AM
neon03se's Avatar
neon03se
i believe that means that there is a bad connection on the cluster or something of that nature, i'll try to find out more for you
Old Aug 13, 2007 | 01:07 AM
neon03se's Avatar
neon03se
try the code look up procedure and see what code it is giving you if possible
