Pacesetter Header
Old Aug 14, 2007 | 07:11 PM
antitrustspider's Avatar
antitrustspider
Default Pacesetter Header
It has a 3" collector but the exhaust on the '05 Neon is 2.25". Is that right? And is it just a direct bolt on only needing a ratchet and sockets?
I'd assume installation just requires unbolting the old one, and then bolting on the new one. And replacing the gasket of course.
Old Aug 14, 2007 | 08:30 PM
neon03se's Avatar
neon03se
Default RE: Pacesetter Header
i've read a lot of bad things bout pacesetter, as for the install i thinks its pretty straightforward
Old Aug 14, 2007 | 08:33 PM
contagious19's Avatar
contagious19
its not a direct bolt on. modifications are needed like changing da flange and making holes for da bolts cuz dey dont fit directly, dats wat i went through
Old Aug 14, 2007 | 10:03 PM
antitrustspider
Most people on these forums like the pacesetter headers. A friend of mine says they were the only ones he actually found for the Neon that were made correctly.
Old Aug 14, 2007 | 10:16 PM
neon03se's Avatar
neon03se
hmmm i have read some bad things about the quality....what yr neon do you have?
Old Aug 14, 2007 | 11:01 PM
antitrustspider
2005
Old Aug 14, 2007 | 11:14 PM
das2123's Avatar
das2123
ORIGINAL: neon03se
The header is nice for the price, but the cat-back exhaust system is terrible.
Old Aug 14, 2007 | 11:47 PM
neon03se's Avatar
neon03se
from what i have read on posts about the header, is that in terms of quality pacesetter is considered "low" but as is the OBX which is supposed to be a little better. what does your friend mean by "made correctly"
Old Aug 15, 2007 | 01:20 AM
Adionik's Avatar
Adionik
I heard that the pacesetter goes on a lot better than the OBX.
Are you gonna put the car on jack stands or you have a lift?
Old Aug 15, 2007 | 02:47 AM
antitrustspider
Made correctly as in the pipes go into the collector in the same order as the firing order. Guess it makes for better air flow.
And I'd be using jack stands.
