new decision on neon
Old Aug 16, 2007 | 09:03 PM
contagious19's Avatar
contagious19
Default new decision on neon
i just decided that turbo is too much of a hassle and srt swap takes too much time. i decided to just build up my motor from head to toe. lol. so dats my final decision. and if i everytin goes good. ill turbo in da future when my engine can take it. now my next mod would b a cold air intake , either though i just bought a k&n air filter. wat ya think?
Old Aug 16, 2007 | 09:18 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: new decision on neon
yea use the filter you have on teh end of the cai and it will be fine.
Old Aug 16, 2007 | 10:59 PM
contagious19
da stock K&N airfilter. dis one http://modernperformance.com/dcx/2k_kn.jpg
Old Aug 16, 2007 | 11:03 PM
Kapitald's Avatar
Kapitald
yeah use the k&n its better than most cheap knock-offs......going all motor is more expensive than going turbo you realize??? all motor will be more dependable though...
Old Aug 16, 2007 | 11:11 PM
contagious19
ORIGINAL: Kapitald
i kno it will. it will also take a lot more time. just for future refrence wat cam is good for turbo? i mean i would like to do da swap but its too complicated. im still not really sure on wat to do. i think i should just get a srt-4.
Old Aug 16, 2007 | 11:17 PM
Kapitald's Avatar
Kapitald
thats what i did (got a srt-4).....the hardest thing to do after the swap is tune with MS like mikey is doing.....the car will be down for probably 4-5 full days if you take your time installing the turbo setup...and thats just install not tune.....but i believe with turbo cars you want low compression bc the turbo builds alot of pressure....so you would want a cam that gives you a low compression....AND SEE THAT WOULD SUCK FOR A ALL MOTOR CAR BECAUSE THEY NEED HIGH COMPRESSION lol.....so you have to kinda pick a way....instead of cam first you can do eagle rods and j.e. pistons first.....titanium valve springs and retainers....get a new intake manifold as the oem plastic one wont hold up under high boost...and maybe some headwork...THEN THE CAM AND TURBO....lol or just go like me and get a srt-4 lol
Old Aug 16, 2007 | 11:24 PM
contagious19
i think ima get a srt-4 and keep my neon. lol naw all motor for now
Old Aug 16, 2007 | 11:25 PM
contagious19
i think ima get a srt-4. lol. naw im just going to build up my motor. yea ill get da cam later
Old Aug 16, 2007 | 11:30 PM
Kapitald's Avatar
Kapitald
i would definately start with the rods and pistons first then....and look into other parts if your thinking about turboing later.....like look into a transmission or oil pan extension so you can hold more fluid...= safer......crank scrapper and windage tray are good too....got a auto might want a transmission cooler...
Old Aug 16, 2007 | 11:34 PM
contagious19
oh shi* i posted twice. naw its a 5 spd thanx for da advice Kaptald, so i need a tube for a CAI and just stick my K&N filter. i think next would be a intake manifold and throttle body and den ima get inside da belly of da beast and put new rods and pistons
