Comp 400 Cam...
Old Aug 20, 2007 | 09:20 PM
neon03se's Avatar
neon03se
Default Comp 400 Cam...
i plan on keeping my car N/A and am looking for a lil more in the performance department. yes i have an auto but i'm working with what i have. Now would a comp 400 cam be good for my car considering the mods that I currently have (in my sig)...or should I get somethin else...thanks
Old Aug 20, 2007 | 11:12 PM
neon03se's Avatar
neon03se
Default RE: Comp 400 Cam...
bump
Old Aug 21, 2007 | 01:22 AM
03neonRT's Avatar
03neonRT
A Comp 400 is designed for the Magnum cylinder head, so you wouldnt see as much gain on a standard SOHC head. If I were in your postition I would go for the Crane 12, Magnum Cam, or Comp 200, but not necessarily in that order.
Old Aug 21, 2007 | 01:46 AM
neon03se's Avatar
neon03se
which is better in terms of quality or all they all equivalent, also in performance
Old Aug 21, 2007 | 01:53 AM
03neonRT's Avatar
03neonRT
IMO, the Comp 200 and Crane 12 are "identical" in performance and quality. The Magnum cam is the same quality, but a little less performance wise (but its also cheaper)...
Old Aug 21, 2007 | 02:00 AM
neon03se's Avatar
neon03se
alright thanks for the answer, by the way whatever happened to your cam...
Old Aug 21, 2007 | 02:25 AM
03neonRT's Avatar
03neonRT
Do you mean what happened to my Magnum cam or the Comp 400 that I have now?
Old Aug 21, 2007 | 01:19 PM
neon03se's Avatar
neon03se
didn't you have a mag cam FS?
