Wheel Lug Nut Bolt Snapped!! Need Help!
Old Aug 25, 2007 | 01:28 PM
technical18's Avatar
technical18
Default Wheel Lug Nut Bolt Snapped!! Need Help!
Ok, i was trying simply to take my wheel off when all of a sudden one of the bolts snapped and broke clean off.
What do i need to replace and where can i get it?
Also is it safe to drive with 4 outta 5 nuts in place until i can get the part?
Old Aug 25, 2007 | 02:35 PM
Adionik's Avatar
Adionik
Default RE: Wheel Lug Nut Bolt Snapped!! Need Help!
Yes it is. Because that is EXACTLY what happened to me a week ago. A tire shop wanted 35 bucks to fix it...said they had to take off the caliper and all this other BS.
I will get it fixed eventually but until then i'm only on 4 lugs myself...
Old Aug 25, 2007 | 03:19 PM
technical18
i went to autozone and got the part i need to fix it. (wheel stud). problem is i cant get the freakin rotor off!!!!!!
Old Aug 25, 2007 | 03:29 PM
Adionik's Avatar
Adionik
the rotor comes right off...
Old Aug 25, 2007 | 03:38 PM
technical18
ok problem fixed with a $2-3 wheel stud fom advance autoparts
Old Aug 25, 2007 | 03:39 PM
technical18
ORIGINAL: Adionik
yeah it did after a little beating with a hammer
Old Aug 25, 2007 | 04:20 PM
contagious19's Avatar
contagious19
well da studs are behind da rotor so u need to get past da caliper before u can start.
Old Aug 25, 2007 | 04:35 PM
Adionik's Avatar
Adionik
sigh...i'll do it when i replace my rotors cuz my hand is still ****ed up[&:]
i hate lining up that rotor with the strut. You HAVE to take the rotor off right?
Old Aug 25, 2007 | 04:50 PM
contagious19
yeap
Old Aug 25, 2007 | 08:17 PM
bone33's Avatar
bone33
ORIGINAL: Adionik
it's no big deal, you just take off the caliper and the rotor should come right off, and while you are at it, you can machine your rotors and replace the pads if you feel like it.
