Tranny issues
Old Sep 2, 2007 | 01:50 PM
MoparMan00's Avatar
MoparMan00
Default Tranny issues
Basically, I bought a 2000 neon, 5 speed, in march of 06, it ran fine/still does. When I bought it i noticed that the shift stick had a lot of play, when its in a gear, you can move it around so much that it felt like it was in neutral. I sort of babied it so it would last. All of the sudden the other day, I could not get it into reverse. It took about five minutes to do so, and it was fine. This morning, I was parked on the side of the rode at my girls house, I turned into a drive way to get facing the other direction on the street, I had to push the car out of the driveway, as it would not go into reverse. I think it might be the linkage...after some research. Any ideas?
to give a more detailed description of the problem, its sort of like a solid object in the way of the shifter, not letting it go into reverse. It's not grinding, so I have basically eliminated the clutch...Some help would be greatly apperciated, SORRY for the longish post!
Old Sep 2, 2007 | 08:59 PM
bone33's Avatar
bone33
Default RE: Tranny issues
will it go in with the engine off using the clutch?
Old Sep 2, 2007 | 09:55 PM
j_son600's Avatar
j_son600
Most 5 speeds have a lockout that stops you from shifting from 5th to reverse, maybe its stuck? I am sure you have tried, but maybe try putting it in gear then reverse.
Old Sep 2, 2007 | 09:59 PM
bone33's Avatar
bone33
ORIGINAL: j_son600
good call. i always put mine in 1st, then reverse.
Old Sep 3, 2007 | 03:17 PM
MoparMan00's Avatar
MoparMan00
Not an issue of 5th to first, and it doesnt matter if its running or not......its very intermitten, it has doesnt done it yet today, and only a few times yesterday. but when it does happen, its something that takes like 15 minutes to get to work...GRRR
Old Sep 3, 2007 | 05:59 PM
contagious19's Avatar
contagious19
my neon is da same. wen its in gear it does fell like its in neutral. as far as da reverse thing, mine did da same. now before i go to reverse i put it in second gear den i go to reverse. but wen i do put it on reverse without going to second it grinds. so i go second den reverse try it
