quik question front turn signals bulb color
Old Sep 3, 2007 | 12:30 AM
Yako's Avatar
Yako
Default RE: quik question front turn signals bulb color
yea saw on wikipedia anywhere in the us amber is the only color allow for front turn signals, doesnt say anythin about white bulbs, i guess as long as the light is amber itll be fine
Old Sep 3, 2007 | 10:48 AM
bone33's Avatar
bone33
316.234 Signal lamps and signal devices.--
(1)Any vehicle may be equipped and, when required under this chapter, shall be equipped with a stop lamp or lamps on the rear of the vehicle which shall display a red or amber light, visible from a distance of not less than 300 feet to the rear in normal sunlight, and which shall be actuated upon application of the service (foot) brake, and which may but need not be incorporated with one or more other rear lamps. An object, material, or covering that alters the stop lamp's visibility from 300 feet to the rear in normal sunlight may not be placed, displayed, installed, affixed, or applied over a stop lamp.
(2)Any vehicle may be equipped and, when required under s. 316.222(2), shall be equipped with electric turn signals which shall indicate an intention to turn by flashing lights showing to the front and rear of a vehicle or on a combination of vehicles on the side of the vehicle or combination toward which the turn is to be made. The lamps showing to the front shall be mounted on the same level and as widely spaced laterally as practicable and, when signaling, shall emit white or amber light. The lamps showing to the rear shall be mounted on the same level and as widely spaced laterally as practicable, and, when signaling, shall emit a red or amber light. Turn signal lamps on vehicles 80 inches or more in overall width shall be visible from a distance of not less than 500 feet to the front and rear in normal sunlight, and an object, material, or covering that alters the lamp's visibility from a distance of 500 feet to the front or rear in normal sunlight may not be placed, displayed, installed, affixed, or applied over a turn signal lamp. Turn signal lamps on vehicles less than 80 inches wide shall be visible at a distance of not less than 300 feet to the front and rear in normal sunlight, and an object, material, or covering that alters the lamp's visibility from a distance of 300 feet to the front or rear in normal sunlight may not be placed, displayed, installed, affixed, or applied over a turn signal lamp. Turn signal lamps may, but need not be, incorporated in other lamps on the vehicle.
(3)A violation of this section is a noncriminal traffic infraction, punishable as a nonmoving violation as provided in chapter 318.
History.--s. 1, ch. 71-135; s. 184, ch. 99-248; s. 12, ch. 2000-313.
refference http://www.leg.state.fl.us/Welcome/i...TOKEN=72754367
Old Sep 3, 2007 | 11:58 AM
Yako's Avatar
Yako
ORIGINAL: bone33
kool so i can white bulbs
Old Sep 3, 2007 | 01:55 PM
neon03se's Avatar
neon03se
ha i was right, white or amber
Old Sep 3, 2007 | 10:38 PM
AirWolf's Avatar
AirWolf
I have the kind of bulbs in my sides and turns that are rainbow colored . Never got in trouble for them and also have the 7 colored leds bulbs in my black leds for my backups.
Old Sep 3, 2007 | 11:16 PM
Kapitald's Avatar
Kapitald
hey guys my electric blue srt-4 has clear corners and looks like blue bulbs....not a big deal...the bulbs in my car apparently dont light up blue enough....just makes the clear corners look white...maybe a hint of bluish green....mostly white....and to get a ticket for something like that you would have to have a cop that is a major dick
Old Sep 4, 2007 | 06:08 AM
Yako's Avatar
Yako
ORIGINAL: Kapitald
u mean 8 out of 10 cops
Old Sep 4, 2007 | 02:46 PM
contagious19's Avatar
contagious19
^^^^ but ull only get a fix it ticket, i have my clear sides wit a white bulb, and its suppose to be amber
Old Sep 5, 2007 | 01:15 PM
whtdoesitmatter's Avatar
whtdoesitmatter
well blue is deff a no if u put on ur four ways [&:] lol other than that white i don't think they care about too much
