will this work???
Old Sep 12, 2007 | 12:06 AM
2003SXTneon's Avatar
2003SXTneon
Default will this work???
will this thermal r&d bolt up to my sxt_2.0?
I ask B.c i think it was made for a r/t!!
Old Sep 12, 2007 | 12:56 AM
contagious19's Avatar
contagious19
Default RE: will this work???
i think it would, i dont know why it wont
Old Sep 12, 2007 | 12:58 AM
neon03se's Avatar
neon03se
it will bolt on....
Old Sep 12, 2007 | 02:21 PM
2003SXTneon
thanks i figured it would i just needed a second opinion.
Old Sep 12, 2007 | 10:15 PM
l_pillon's Avatar
l_pillon
looks like my vibrant..did it come with a stainless steel cupling? if not then ur gonna need one
Old Sep 12, 2007 | 10:16 PM
Izero's Avatar
Izero
mine didn't come with a cupling.... where can i get one?
Old Sep 12, 2007 | 10:56 PM
redbirdhky6's Avatar
redbirdhky6
should bolt up, but might look kinda weird if you dont have the cutouts on your bumper because its the exact same size as the r/t. i have it on my turbo r/t and it sounds awesome, i just had a little prob with the clamp. it doesnt want to clamp all the way, so there is a tiny exhaust leak
Old Sep 12, 2007 | 11:27 PM
l_pillon's Avatar
l_pillon
ANY AUTO PARTS STORE WILL HAVE A STAINLESS STEEL CUPLING...MY VIBRANT BOLTED UP PERFECTLY AND HANGS PRETTY TIGHT...MINE DIDNT COME WITH THE CUPLING....THE CUPLING ON 1 END IS MEASURED FROM THE INSIDE DIAMETERAND THE OTHER PART IS MEASURED FROM THE OUTSIDE DIAMETER...THINK MINE COST LIKE 12BUCKS OR SOMETHIN...ALL WAS NEEDED FOR MINE WAS A 15MM SOCKET...GOOD LUCK
Old Sep 13, 2007 | 12:19 AM
03neonRT's Avatar
03neonRT
If it was made for an R/T you might need to buy the midpipe adaptor...
Old Sep 13, 2007 | 08:32 AM
04r/t_11's Avatar
04r/t_11
Yeah, you most likely will need the adapter, that's a 2.25" connection. I have that rear section as well. It sounds great. I had the Borla, kept the mid section, but it had no resonators so it was pretty nasty at first. I threw a Thrush glasspack in the mid section and I think it's one of the best sounding exhausts I've owned. Over a Borla/Mopar, magnaflow, and pacesetter! Enjoy!
