which clutch???
Old Sep 13, 2007 | 09:11 PM
tankhardrive's Avatar
tankhardrive
Default which clutch???
i need a new clutch before i turbo the car... now i donno which one i want they are all close to the same price soooo just trying to decide.....
Stage I - SPEC Dodge Neon high clamp pressure plate with SPEC Dodge Neon organic disc clutch kit (comes with solid steel flywheel) [align=center]295 ft-lb $399[/align][align=center][/align][align=center]Stage II - SPEC Dodge Neon high clamp pressure plate with SPEC Dodge Neon kevlar disc clutch kit (comes with solid steel flywheel)[/align][align=center]360 ft-lb $459[/align][align=center][/align][align=center]Stage III - SPEC Dodge Neon high clamp pressure plate with SPEC Dodge Neon sprung-hub race disc clutch kit (comes with solid steel flywheel)[/align][align=center][align=center]435 ft-lb $459[/align][align=center][/align][align=center][/align][align=center]i know the 295 will be enough for the 8psi ill run at the start but i do plan on rebuilding the engine and jacking up the boost soooo i just dont want to pay399 now and 459 later you know.... and i've driven a few cars with stage 3 clutchs and know they are real jerky and not as nice swifting... [/align][align=center][/align][align=center]so what do you guys think? [/align][/align]
Old Sep 13, 2007 | 09:16 PM
tankhardrive
Default RE: which clutch???
also whats an avarage price on a clutch install? i think last time if i remember correctly it was 400 sum but i cant remember if that included the new oem clutch or not....
Old Sep 17, 2007 | 10:43 PM
tankhardrive
bump?
Old Sep 17, 2007 | 10:48 PM
contagious19's Avatar
contagious19
um i got my clucthed installed for 150 and it a Sachs performance clutch. i say go for da stage 3 if u plan on rebuilding ur engine and running higher boost
Old Sep 17, 2007 | 10:55 PM
tankhardrive
ahhh thank you if its only 150 that not bad i just didnt want the 459 clutch then a 400 install [:@]
Old Sep 17, 2007 | 10:58 PM
contagious19
i think he charged me 250 but im not sure but i dont think 400
Old Sep 17, 2007 | 10:59 PM
tankhardrive
yeah thats still better then what i got the last time but i think that included the clutch....
Old Sep 18, 2007 | 12:09 AM
GrApHite03's Avatar
GrApHite03
stage II is not that bad... i beat the **** out of mine for 60,000 miles before i sold the car. ('03 turbo)
