turning sxt to srt
Old Sep 28, 2007 | 11:20 PM
718sxt.4's Avatar
718sxt.4
Default turning sxt to srt
does anyone no which engine i can put in my sxt 04 to have the same power as a srt i heard the pt crusier high output one is gud but i dnt kno which one wud fit
[/align]
Old Sep 28, 2007 | 11:31 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: turning sxt to srt
SRT motor or pt cruiser will fit. Just search, theres plenty of info about it.
03neonRT's Avatar
03neonRT
The SRT-4 engine and the PT Cruiser GT engine are nearly identical. If you went with the PT engine you would need an SRT-4 intake manifold, motor mounts, and the wiring harness/PCM from an SRT-4...along with all the other swap parts obviously.
Old Sep 29, 2007 | 03:00 PM
718sxt.4's Avatar
718sxt.4
o ok but my sxt is auto.. so which engine wud b better can the srt-4 engine or pt go wit a auto transmission.. an do u no the list of wat i wud hav to do
[/align]
Old Sep 29, 2007 | 06:23 PM
03neonRT's Avatar
03neonRT
For the SRT-4 turbo engine, you will need the following parts:
Engine and Tranny
Complete Engine Wiring Harness
Complete Engine Bay Wiring Harness
Power Steering Pump, lines, and cooler
Clutch master and slave cylinder
Clutch/Brake Pedal assembly
Intercooler Piping
Intercooler
Radiator Hoses
Tranny, Upper and Lower Motor Mounts (the holes are larger on the the upper and lower mounts for larger bolts and the tranny mount is completely different)
SRT PCM (wont' need the bracket with 03+)
Axles (and half shaft if it isn't on the engine)
Coolant Bottle
Fuel Line (from tank to engine bay)
Fuel Pump
Flex Fuel Line (from solid fuel line to fuel rail)
Short evap hose that comes from the purge valve
All vacuum lines and the 3 selonids
o2 Sensors
Turbo Housing + O2 Housing
Lower Control Arms (they're stronger yet the same in shape)
Sentry Key Module + Key that matches the PCM VIN number.
Radiator
Some options parts would include:
SRT Power steering rack (it's shorter)
Knuckles
Flexiable Brake Lines
Calipers
Rotors
As for the transmission, your 4-speed automatic is similar to the auto transmission thats used in the ATx PT Cruiser GT, but your transmission wont hold up for long under such harsh conditions.
Old Sep 30, 2007 | 12:45 AM
718sxt.4's Avatar
718sxt.4
o ok do u no of any place that has all that.. an wat wud happen to the transmission ..wud i be able to get atleast a racing auto trans that can hold up.. the parts u name will that got in the automatic with no problems
[/align]
Old Sep 30, 2007 | 02:01 AM
Yako's Avatar
Yako
a PT Cruiser GT engine has as much power as an 03 srt(stage 0)
<<< or so i heard
Old Sep 30, 2007 | 02:13 AM
spikeymikey87's Avatar
spikeymikey87
it does, and if you really want a auto tranny, the pt cruiser turbo came with a auto, but id go manual if i was you
Old Sep 30, 2007 | 02:02 PM
Yako's Avatar
Yako
ohh yea them PT GTs also came in automatics, if i was rich i'd get me a 07 or so pt cruiser gt and do a swap with my neon cuz them pt's just plain ugly for old people ha
Old Sep 30, 2007 | 05:44 PM
718sxt.4's Avatar
718sxt.4
spikey y wud u go auto..
[/align]
