Help Wiring Halos!!
Old Oct 18, 2007 | 01:42 AM
contagious19's Avatar
contagious19
Default RE: Help Wiring Halos!!
for ur halos, do da parking lights if u want them to turn on wit ur parking lights. if u want them to turn on wit ur headlights dan splince into ur headlights
Old Oct 18, 2007 | 09:12 AM
redbirdhky6's Avatar
redbirdhky6
so do i complete cut the wire behind the parking light and splice in behind the connector or do i leave the wire from the car in the connector the bulb goes into?
Old Oct 18, 2007 | 09:44 AM
ricerchik02's Avatar
ricerchik02
I completely cut off the parking bulb since there was no room to work. They don't pull out very far! Then I used wire connectors to connect the led/halos to the wires in the car to the bulb I cut off. Pics below:
These are the connectors I used. U can cut off a section with a razor blade.
Final product. The halo wires and car wires spliced together go into the top of the connector, the bulb wires go into the bottom of the connector.
Old Oct 18, 2007 | 09:46 AM
ricerchik02
I made a how-to, just haven't submitted it yet. Let me know if u want me to send it to you. I haven't had a single problem with my headlights after installing them this way.
Old Oct 18, 2007 | 11:35 PM
redbirdhky6
yea that would be great if you could pm them! thanks
