Stalling in an AUTO!
Old Oct 8, 2007 | 09:39 PM
unleashedcc's Avatar
unleashedcc
Default Stalling in an AUTO!
MY CAR auto 02
I have a few problem, lets see if someone can point at me in the right direction. When I'm at a light in (D) my car appears to idle low and it starts shaking a lot like its about to stall.
I have done, transmission, power steering, radiator flushes, use reg gas, use semi synthetic oil, using iridium spark plugs. Also I've noticed numbers on my engine block as well as my transmission block, like junk yard parts ??? my title is clean, I bought it in a dealer at 42k, it's always had massive lag, way more than my girls 02, no signs of crashes either. My light for low gas does not work for some reason. the problem of power comes and goes, its not continuously.
MY GIRLS 02 auto
It stalled the other day when she was backing up. She was parked, put it in (R) and boom, it shook a lot then it turned off. She says at lights she has to put it in (N) so the rpms go back up, at a stop it idles below 5rpms, then when you place it in (N) then back to (D) it idles at 7.5rpms. ANYONE???? lol
Is it a common problem, anything could help. Ive done fuel pressure checks and its normal, I did a compression test by removing each spark plug and i get 160psi all the way through. no codes.
Someone please help
Old Oct 8, 2007 | 10:03 PM
neon03se's Avatar
neon03se
Default RE: Stalling in an AUTO!
i noticed you changed the plugs but not wires, check into that. would be wise to change them when you change your plugs
