PO340 Camshaft Position Sensor misfunction
Old Oct 9, 2007 | 09:11 PM
haha_haha's Avatar
haha_haha
Default PO340 Camshaft Position Sensor misfunction
I'm guessing I'll probably have to replace the thing...but I'm not sure what the heck it is.
could someone quickly explain how it looks like (and where it is located) on a 2002 dodge neon automatic
and a short guide to replacing it would greatly help! thanks!
Old Oct 9, 2007 | 09:17 PM
GrApHite03's Avatar
GrApHite03
Default RE: PO340 Camshaft Position Sensor misfunction
drivers side of the head...
Old Oct 9, 2007 | 09:18 PM
03neonRT's Avatar
03neonRT
Its located on the drivers side of the cylinder head just under the valve cover. Its just a small black square with a connector coming off of it...all you need is to disconnect the wire and remove four bolts. Do the process in reverse for the install and your done...should take no more then 5-10 minutes.
haha_haha's Avatar
haha_haha
Aye, thanks!
aaaand, one more question, sorry[:@]
but would cam position center have caused misifire in spark plugs? thanks.
Old Oct 9, 2007 | 09:40 PM
Kalevra's Avatar
Kalevra
Yes! it would cause a misfire
